#151
| Thoughts on the A-Frame As I am building a 50 George Buehler sailboat, I plan to incorporate the A-Frame concept with the Aft-Mast configuration. In this way, I can eliminate altogether the Main Sail, and instead incorporate 2 Gibs that will do the work. I may in the future add a mizzen, but at first I will try without. I am very interested in others that have tried the A-frame, and would also like to know what others think of the Aft-Mast. Thanks for the update. |
#152
#153
Here's a good picture of the rig. One thing I don't understand is why he left the bottom of the mainsail so high. It looks to me like I could get the foot of that sail another 'foot' or two longer/lower, improving the sail efficiency. But the builder did put some hardware at the front of the wheelhouse that sticks up a foot or so, so maybe that's why. ![]() |
#154
| I have seen this, and was very impressed. The difference though, is I wish to rake the mast forward as per the Aft-mast configuration, and use three stays, which will be used as two gibs and a permanent Storm Sail. I could then in the future also incorporate a ketch, but for starters, I could do without. Thank you for the link to your site. I had it on one of my earlier computers, but it went out with the hard disk that I had to replace. Could you give us some of your thoughts on the A-Frame, and how it worked out? |
#155
#156
I did post a couple of items about the aerodynamics in post #150 a little while ago - you may not have seen it. But I will say that the masts indeed are very light - I think about 200 lbs. each even with the hardware. They have an airfoil shape with an internal cross-membrane - the cross section looks like a figure 8. I'm unfamiliar with the aft-mast thing you are talking about. How does that work? Is it akin to 'suicide doors' on the old cars? |
#157
| I should mention that the masts are over 52 feet long. |
#158
| To start, you could look at www.runningtideyachts.com to view the Aft-mast configuration. The Idea is to rake the mast forward about 10% and connect to it two Jibs, eliminating the Main Mast and Boom. I thought, gee, nice, but wouldn't it be more reliable with an A-Frame? So by combining the A-Frame in an Aft-Mast configuration should actually bring a lot of benefits. |
#159
| Also, with the Aft-mast rigging, the sails would not overlap the masts like what we see in the above picture that you sent. This would allow for closer hauling of the sails, maybe even using sail tracks on the deck for sharper tracking. |
#160
__________________ Tom Siders A-Class USA-79 Tornado US-775 |
#161
Possible he will be able to shed some other light on the designer and his work? Meantime he referenced me to some other photos: http://www.nahiku33.com/mw.html |
#162
| Relentless nee Nimrod It was Nimrod. The photos shown were taken at Railway Marina, where we are now moored on Puget Sound. As in my other posting (other thread) Nimrod/Relentless is now at John Wayne Marina and has had it's keel removed (it did not go willingly), mast shortened, power plant upgraded, and a doghouse stuck on the stern. It is not the same boat. Still has a get home bipod rig only. I have the DWGs for the boat also. Since the boat had long since been sold by the original owners before it got to Railway, I doubt any new light will be shedding, but I'm just a skeptic... Orca remains intact. |
#163
#164
| Hove to Just wanted to add that a few days later we did heave to under staysail only. The boom made itself very useful. Very comfortable ride, well-balanced. Attached another shot from a blustery day some years ago in Oregon. |
#165
| A-Frame Rig on 'Catbird Suite' Somehow I missed ever seeing or knowing of this vessel, but here is a gentleman who is not affraid to experiement. Just happened across this vessel this afternoon. Perhaps we'll encourage the owner to add some comments to this forum. http://www.damsl.com/ "The rig is my idea (tested on a smaller catamaran) with engineering and construction specifications by Malcolm Tennant and Anthony Stanton of New Zealand design team Malcolm Tennant Multihull Design (tennantdesign.co.nz), who designed the boat. Dave Pope, who was a member of the Tennant team, did the original construction drawings of this boat and has contributed a lot to development of the new rig. Dave now has his own design firm and is based in Whangarei (dpd.co.nz). The rig was completed in December, 2006. It works very well, is quite efficient upwind, is especially good reaching and running, and is easy to handle because all sails furl and there are other advantages as well........." .....more discussions, photos, and videos |
| Aftmast rigs??? | jdardozzi | Sailboats | 492 | 03-22-2012 03:11 PM |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 07:19 PM |
| Foiler Design | tspeer | Sailboats | 1031 | 12-17-2010 01:38 AM |
| Motor Sailers? | Viceroy | Motorsailers | 288 | 09-06-2009 06:21 PM |
| Motor Sailors | dlynch | Motorsailers | 15 | 04-06-2005 03:16 AM |
