Old 07-11-2006, 02:11 PM
JonBoyee JonBoyee is offline
Rep: 10 Posts: 3
Is This A Wise Decision?, Any Advice?
I have an 11ft Jon boat and am on a limited budget and I was thinking about
Taking some advice that I learned from this forum with pvc and abs pipeing used for a pontoon, but all I want to do is add a pontoon made from one of these materials to each side of my boat to add some more stability so I can stand and move around , because by no means am I a small man.
I was wondering if this is a wise decision? And I could use some advise on mounting the pipe so that i can take it on and off for transpirtation purposes?
Thank You Folks Very Much,
Jonathan M.
Old 07-11-2006, 03:31 PM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
Why wouldn't it be a good idea? If you have to worry about tipping over every time you fight a fish (or whatever you're doing ), sounds like you're on the right track to me.
As far as mounting options, seems like that would be pretty simple to do. Bolt or better yet weld some reinforcement onto the sides of the boat and maybe to the tops of the seats, to spread the load, and you should be able to bolt some kind of support frame on without too much trouble.
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Old 07-12-2006, 08:48 PM
Rep: 10 Posts: 3
Thank you very much, I was just needed a word of confidence to move forword. another piece of advice i could use is it illigal to make a trailer out of wood minus the chasis?
Old 07-13-2006, 10:39 PM
Rep: 42 Posts: 438
That would be a question for your local dmv.
Stonebreaker
Old 07-14-2006, 04:34 PM
Rep: 10 Posts: 3
thanks
eska counter clock wise prop silkyeagle Press Releases 0 07-03-2006 06:13 PM
need some advice lurch1 Open Discussion: All Things Boats & Boating 1 04-26-2006 03:45 PM
Need some wise advice with volvo outdrive! Fish Mode Boat Design 2 10-24-2005 12:10 AM
Decision Time Wynand N Boat Design 8 01-26-2005 05:51 PM
Decision of the Shaft Center Line position in Twin Screwed Boats Donald Boat Design 0 03-29-2004 08:52 PM
