| Wire Rope Anchor Rode I'm designing the anchoring gear for a 42' cutter I'm building. I'm interested in the use of wire rope as a replacement for chain. It's 1/4 the weight for the equivalent strength of G40 chain and costs 1/3 as much. Storing it tangle free on a drum sounds appealing. I'd like to hear feedback from any members that have experience with wire rope as an anchor rode. In particular, what is effective at protecting it from corrosion (grease?), and how well it holds up in use. Regards, Paul |
| Pauls, Some fishermen use it here in Alaska on their drum winches but I've heard very little about how well it works. Could be the key element in an ideal anchor rode in that it would certainly come close to providing ideal weight distribution to bring about the most effective catenary possible. A very short length of super heavy chain of about 3' followed by 8 to 15' of heavy chain followed by wire would keep the anchor shank down so the anchor will provide it's best performance. Given enough swinging room one could have a very long scope. I would think a level wind and some kind of tensioner would almost be required for seamless anchor retrieval. Remember the trailer boat winches w wire on the winch? What a mess. That could be the reason wire anchor rodes are not very common. Easy Rider |
| At 1/4 the weight of chain, this is a huge disadvantage. Part of the benefit of having weight next to your anchor is to keep your angle of attack low there-by simulating a greater scope. This helps keep your anchor embedded in the sea floor. The weight also acts as a shock absorber while the hull takes wave action and surge on the surface. |
| Chain has weight. Otherwise, we'd all use rope instead. Wire rope is relatively light. In addition, it does not coil unless it is twisted 360 degrees with each coil laid down. It would have to flake or lay down in a figure eight. Chain on the other hand has so much rotational freedom that it lays down perfectly. You could use a big reel to store the steel rope, true. Maybe just under the deck. But the reason nylon is used for rodes is that it stretches a lot, which is exactly what's needed to prevent shock loading. The chain does the same thing by lifting its weight with an effect similar to stretching. It's the weight of the chain that helps to set the anchor, causing the anchor to pull horizontally. While wire rope may have some limited use anchoring, I don't know if it would be useful on a 40 ft sailboat. |
| For boats that anchor overnight with no deck watch, chain or chain/rope would be safer than wire rope. In a gust the boat will surge back , the Wire rope has tiny catinary so transfers the load directly to the anchor. Chain will lift and need to be dragged along the bottom, lowering the forces on the anchor . Probably the "best" is half chain , half properly sized nylon (Anchors and Anchoring.. Van Dorn) This seems to give the best results , esp if anchoring in deep (over 100ft for most) water. FF |
| The combination of chain and high tensile rope is a proven compromise when a anchor weight is attached. But thats more often than not a mess on the windlass capstan / chain wheel. And the anchor weight is another part to handle and store. When you have no problem with weight, the chain is still the best solution. Regards Richard |
| I know that Brent Swain, the fellow who designs the origami sailboats, specs wire rope and a hand operated windlass on his sailboats. He claims good success with them. As long as you have a decent windlass/fairlead arrangement and a good chunk of heavy chain at the anchor, why not? Good quality galvanized wire rope will last for years. Chuck |
| FRED, Yes, I forgot about the stretch factor. All things considered wire rope dosn't sound like a good solution. I use that new anchor line called "Brait". LIke it very much. skypoke, I agree. I think the chain should be the smaller part at the anchor end. Easy |
| I think the chain should be the smaller part at the anchor end. Something to think about for the folks that prefer a nylon rode , the short chain can be way over sized ,since it need not go thru the chain gypsy. It MUST fit thru the bow roller , but if it stops short of the windlass/capstan , a fine heavy size can be used. Actually wire rope is an ideal solution for the fish guys. They frequently anchor , move , anchor , move and the wire can be remotely dropped or recovered from the pilot house. Since there working , dragging is of little concern , its just a slow way to a downwind spot. FF |
| Wire lasts far longer than fiber rope and has a smaller diameter than all but the spectra ropes. It is used all the time here with good success but one still needs chain for catenary (chain - catena - catenary) and for chafe resistance. It lays nicely on a winch and with a little guidance (a prying point and a bar in front of the winch), it will lay perfectly. The smaller diameter comes into play when anchoring in current in deep water for some fishing operations. A wire roded boat will stay on a delicate hold in more current (because of the smaller diameter) than fiber ropes and weighs less than all chain. The touted stretch of nylon is insufficient to do anything positve - Nylon is used because it sinks, is strong, doesn't much degrade, and somebody said its stretch will keep your anchor from pulling. That being said, the stuff Easy uses is good for small boats but one still needs chain. Spectra (UHMW, Dyneema is slightly better/more expensive) fibers have almost entirely replaced wire on winches here because of the tangle problems with wire Easy mentioned. I have anchored in deep water with an added shot of spectra and it worked very well. My personal preferred set-up now for a forty foot boat or so is; as much chain as one feels he can afford in weight (maybe 60' of 3/8" - I use only 25 feet of 5/16" because I anchor in rocks with very little scope but I have a bigger anchor/more,heavier chain onboard.), several hundred feet of nylon (consider it expendable and the only part that wears and needs replacement every few years unless you break an anchor), then the rest in spectra rated higher than the nylon - If it ever were to part (if I get a little fray near the bottom of the rode from a rock, I leave it - that way, when it parts it will be near the bottom and all I have lost is anchor and chain - remember I am in rock 90% of the time. The bugger is re-eyeing the double braid nylon after it ages.), the nylon would serve as your weak link, the nylon will be used a vast majority of the time, and when you fish in 600' or in a 2knot current in 200', you'll appreciate the spectra, which was kept nicely out of the sun by the covering of nylon on the winch. I wouldn't use wire on a windlass and one wud need a large diameter head to accomodate it anyway. Spectra works well, flakes well, but requires more wraps to keep from slipping. |
| Mark, Excellent post. Interesting about the current. One can learn from stuff like this. So your'e in the rocks up there eh? Mark ...what type of anchor do you use and do you have any tricks or info for short scope work? I use the Brait line cause it always comes out of the box just as easily as it went in. They say with a properly sized anchor and rode the rode will become straight, without catenary before the anchor rips out. That would mean the catenary is really only good for setting and reducing shock load for long periods of cyclic pulling (as in waves overnight). It appears that without the waves one would be as well off w a super light but strong enough line and say "who needs catenary"? There seems to be endless angles for anchoring. Easy |
| Well, Easy... When fishing, I anchor two to seven or eight times a day but the techniques I use are contrary to secure anchoring (staying put overnight, e.g.) in typical conditions. Solid jagged basalt holds amazingly well. When in rocks (basalt or coal/shale, jagged), I minimize the scope, usually just 1 1/2 to 1 and the anchor will find a home almost intantly that will not pull out until pulled forward on. Danforths, Fortresses, etc. are one-time use in this circumstance, expensive anchors (CQR, Bruce) are a waste, tho I used Bruces or a Davis SeaHook/Furfjord with a break-away until Lewmar started importing the cheap Chinese junk. The cool thing about these lousy anchors is, tho I feel guilty using them and they are ugly, they will break if you really reef on 'em and you save your chain, the store gives you a replacement (until they catch on - try Redden Marine in B-ham), and they are cheap enuf that anyone can afford spares. Their breaking propensity is reliable enuf that a break-away tie-up is unneccessary and, in fact, undesirable as it makes your hold less stable - simply use a little heavier rode than otherwise (I use 3/4" Sampson Braid @ nom. 19,000lbs. and add 7/16 Amsteel Blue Dyneema @ 21,00lbs.) and pull forward and at an angle and the anchor shud break if badly hung (40', 18,000 pounds). Letting the chain and rode get wrapped up in rock will get more expensive. Much scope is bad here. Of course, anchoring anywhere else will entail conventional technique. These type anchors hold nowhere near as well as Danforths and such in sand, clay (the best holding if you can find it) or gravel. When the Chinese learn to copy metalurgy as well as shape, the anchors will no longer be as good! I think I remember a pic of your boat and somthing like 7/16 soft stuff like you mentioned (the stuff that doesn't tangle easily - I've read about it), 20 ft. of 1/4" chain and a ten kilo Lewmar (Jokingly refered to as "Bruce Lees" - playing on the quality Bruce anchor name). Have another 30' of chain available and a 15 kilo "storm" anchor and you can anchor in less ideal conditions, as well, but I doubt your boat will easily break the 15 if it gets hung. Lotsa rode is for sand. It's better to leave an anchor and get it in nicer conditions than it is to risk trying to break in rough water (I'm saying for other reader's benefit - I know you are aware). |
| There's a 61 metre car ferry near here that has wire rope anchor rodes. She has a Navy-style anchor on each end, then about 4-5 metres of very heavy chain, then wire rope of about 2.5 cm diameter. I'll take a closer look next time I go to the island. Wire rope won't flake down in a locker. But stored on a drum, it might work very well. Take a look at the winch drum of a tower crane next time you're at a construction site- a similar design might work for anchoring applications. You'd need guides of some kind, possibly like those on a baitcast reel, to stop it from forming rats' nests on the drum. Attaching a snubber or bridle to a wire rope anchor rode could be difficult. Ideas? As for weight- the advantageous catenary effect approaches zero as the wind picks up, which is exactly when you want the holding power at its best. An extra kilogram in the anchor itself has a much greater effect on holding power than an extra kilogram in the rode. For a given maximum total weight of the ground tackle system, I'd prefer to put as much weight as possible in the anchor and relatively little in the rode. Chafe resistance in the 10 metres or so closest to the anchor may be a factor to consider..... I don't think wire rope holds up as well as chain when chafing.
| Another excellent post and I learn again. I was wanting a Manson Ray (the better part of $1000) but decided on the Plastimo Manta ...cheap by comparison. I see some claw anchors on fish boats in Craig that are bent. I didn't know the metal in those things was that malleable. It's interesting that the Lewmars actually break. At least you get your rode back.Perhaps the bent one's are real Bruces. Despite all the talk it seems the claw anchors do work very well. My Brait is 5/8 and I've got 350' of it so I could afford to loose some so the sacrificial anchoring you refer to may (to some extent) work for me. marshmat. Exactly my thinking .....put the weight in the anchor. |
| How to cut wire rope ? | boony | Boat Design | 14 | 04-25-2010 11:11 AM |
| How do I control both sheets from one rope? | miniman | Sailboats | 21 | 08-20-2009 09:03 AM |
| Parachute Anchors, Para-Anchor, Sea Anchor | brian eiland | Boat Design | 28 | 05-06-2009 02:11 AM |
| anchor and anchor winch questions | martinf | Boat Design | 7 | 04-05-2008 06:10 PM |
| So Many Rope Choices | durwoodghib | Sailboats | 24 | 07-30-2007 03:25 AM |
