Old 11-02-2007, 05:45 PM
556Geoff 556Geoff is offline
Rep: 10 Posts: 20
Wing Sails-Masts?
Take a look at this site: http://www.trikini.com/Cheapwingsail/cambercontrol.htm I have been researching wingsails for both multis and ice boat clients. Has anyone had experience with these adjustable wingsail rigs on larger boats? Most wingsails are shape dedicated with one or more slotted flaps to get asymmetry. This rig is very smooth shaped, yet shape adjustable for changing conditions. The rig seems to be far less exotic and not proprietary or secretive in nature of construction or shape. The rig can be either free-standing or stayed too. Does anyone have any thoughts on this rig?
Old 11-03-2007, 02:57 AM
nero nero is offline
Rep: 112 Posts: 624
Looks interesting. I can not get all the pages to load properly. In particular, the page that describes how he get the camber into his wing. Can you post that illustration here?
regards
Old 11-03-2007, 11:06 AM
Rep: 10 Posts: 20
the camber controls: http://www.trikini.com/Cheapwingsail/cambercontrol.htm
How it works page: http://www.trikini.com/Cheapwingsail/HowItWorks.htm
Old 11-03-2007, 12:05 PM
Rep: 112 Posts: 624
Yes it is the ...cambercontrol page picts that will load for me. The text displays correctly. Is there one of the picts that illustrates how the wing works? Can you post the pict here in this thread?
thanks
Old 11-03-2007, 05:51 PM
Rep: 10 Posts: 20
also: I hope this works for you?
Old 11-04-2007, 02:19 AM
Rep: 112 Posts: 624
thanks
Thanks for posting the illustrations. This system looks wonderful!
Old 11-04-2007, 03:26 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Nero,
http://boatdesign.net/forums/showthr...ail#post152124
Pericles
Old 11-04-2007, 09:45 AM
Rep: 112 Posts: 624
Pericles
Thanks for the link.
Old 11-05-2007, 12:58 PM
RatliffFranklin RatliffFranklin is offline
Rep: 17 Posts: 191
Dennis Conner, "Stars & Stripes", 1988. Biggest wing sail to date?
http://www.americascup.com/en/acclop...4926&idRubr=74
Old 11-05-2007, 08:25 PM
Rep: 10 Posts: 20
What I like about this rig is the fluidity, the multiplicity of shapes that can be tried with this rig. What the challenge of this rig is is the number of control lines (#55 for 11 battens) and how to deal with the spagetti of the problem? I'm confident of the rigs abilities to change shapes but I need to come up with a device to facilitate, replicate, and mirror image the shape for tacking to the other tack?
Old 11-05-2007, 10:05 PM
Petros Petros is offline
Rep: 717 Posts: 764
cleaver idea. But if I read this site correctly, you need a separate line from each pair of battens for each direction of tack. This means if you have 8 battens, you will need to adjust 16 lines to control the camber. Not sure if the crew has to uncleat each set of camber control lines for each tack or not, but it seems to me you still need a way of controlling the angle of attack of the rig, and the twist.
I think a junk rig might actually be simpler, and it allow both angle of attack and twist control with one set of controls that do not have to be uncleated with each tack.
One additional observation is that there is a way to control the thickness of the foil section, but I see no advantage. Additional foil thickness only adds drag. On an aircraft a thicker foil means a lighter structure, but that would not happen with this set-up.
Old 11-06-2007, 01:09 PM
Rep: 10 Posts: 20
In lower wind conditions, one might want to use the thicker more powerful foil with the higher drag properties.
Old 11-06-2007, 01:10 PM
Rep: 10 Posts: 20
Also, one might be able to head lower on the wind with a thicker foil section too.
Old 11-06-2007, 01:44 PM
Rep: 717 Posts: 764
If one has control of the camber and the angle of attack, there is no advantage to a thicker foil. There is never an advantage to increased drag (except to perhaps slow down slightly faster when you want to "put on the brakes").
A thicker foil is more stall resistant and gives you a more gentle stall, which is important on a trainer type aircraft. The sharper leading edge radius of thinner sections cause the sharp stall. But seldom is such a condition life threating in a boat because you are going much slower, presuming you are paying attention to your sail position, there is little reason that this should happen at all.
There is no advantage to more drag on your sail in a sail boat.
Old 11-06-2007, 02:19 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 187 Posts: 641
How about "Batwings"? Someone got a Govt grant and designed
foldable/retractable and stowable GIANT batwings for use on large ships(container, oil tanker?).
They were modeled on, well, a bat's wing. He had concept pics with about four in line on a ship. They would fold down into container pods when not in use.
He also made small 'proof of concept' bats wings he put on a kayak and small catamaran.
I think his main idea was that the Batwing/Sail could be easily folded and stowed into a smaller space than any other mast/sail configuration. They would also be easily reef-able.
I haven't been able to find it again online. I can't remember if he published 'the basics' that would allow others to experiment with the concept.
Lightning on masts Fanie Boat Design 42 11-07-2007 07:51 PM
Adjustable-Shape wing sails 556Geoff Sailboats 2 11-01-2007 10:31 PM
wing sails nflutter Sailboats 26 06-10-2007 06:59 AM
Catamran with four masts PrimoPiatti Multihulls 5 12-11-2006 02:14 AM
Wing Sails brian eiland Sailboats 0 05-31-2004 11:15 AM
