Old 03-20-2004, 07:54 AM
Addisu Brhane Addisu Brhane is offline
we have request form a customer to manufacure boat with capacity of 100 people and 30-40 ton capacity boat which may be built from aluminum or steel with two motors. the boat should include all necessary things ,like ramps,radio comminication,direction show,compass,fire protection,small boats,long light,small generator, kitchen,bed room, toilet, living room etc. Thus, please advice us how to manufacure as joint venture, We Mesfin Industrial Engineering a vast engineering complex which produce differnt trailers, depots, penstocks, overhead crane, antenna masts, etc.
Addisu Brhane , addiso99@yahoo.com
Old 03-21-2004, 04:55 PM
stu hearn
i have done all of the methods
The drill is this for glass or lexan planted on outside
Use bedding Sikaflex, use their primer, paint the primer on sealant lands, pack with the sika spacer foam and apply sealant , wedge the work in place, no fasteners what you want is a hardened depth of anout 2mm -3mm , you dont want the work hard up against the metal. Lots of builders in NZ are using glass, toughened planted on with no fastenings, same as in a high rise building, it is an appoved survey method Even boats that pound and jolt rapidly , use this method. If say you cant find a clamping method, like timber crossing the panes, then use a couple screws and draw out afterwards
Stu
Old 05-05-2004, 07:53 PM
68Morgan30 68Morgan30 is offline
Rep: 10 Posts: 4
thru bolts would be better
I agree with most that has been offered on this subject, except the recommendation to tighten the screws after the sealant has set. This will break the sealant bond around the screw and allow water to get into the bulkhead structure. A better process is to use through bolts with nuts on the inside. Tighten bolts only enough to form an even gasket of sealant around the window that is a uniform 1/8 or so thick. After the sealant cures (days with a poly-sulfide) tighten the nuts from the inside while holding the through bolts from moving on the outside. This method compresses the gasket without breaking the seal around the bolts.
On my 68 Morgan sailboat the bulkhead is slightly curved. Is lexan or plexiglass better if you have to bend it?
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Looking for the right path to design and build ben_morel Education 44 11-24-2005 03:51 PM
Yacht Design Graduate Considering Opportunities solbergg Services & Employment 1 11-14-2005 05:37 AM
Yacht Design Services yachtdesigner Services & Employment 1 01-23-2002 04:25 PM
