Old 09-05-2005, 04:44 AM
idkfa idkfa is offline
Rep: 31 Posts: 205
WinDesign vpp - heel angles, 14k lower than 12k
Hello all,
Got some results here of a WinDesign-vpp test I'd appreciate some help with. At wind angle 32degrees, the heel angles for wind 14+ are lower than for wind 12-! and subsequently the speed as well.
Heel angles:
8 9 10 12 14 16 20
32 15.43 18.7 20.35 22.47 6.01 7.77 11.83
36 16.94 20.02 21.35 23.18 24.22 24.88 25.78
40 18.13 20.93 22.11 23.55 24.32 24.87 25.74
45 19.15 21.74 22.63 23.67 24.36 24.9 25.77
Is it, at the higher windspeeds the sails were "further" flatten to keep the airflow laminar, and now they're so flat, that the lift/heeling moment created was very small? But if so, why is the change apparent at 12-14knots?
Any ideas?
Thanks idkfa,
Old 09-05-2005, 04:51 AM
Rep: 31 Posts: 205
reformated results, with spaces
Heel angles:
8 9 10 12 14 16 20
32 15.43 18.70 20.35 22.47 6.01 7.77 11.83
45 19.15 21.74 22.63 23.67 24.36 24.90 25.77
that's better,
Old 09-05-2005, 04:56 AM
Rep: 31 Posts: 205
reformat again, no double spaces
Heel angles:
.....8......9......10......12.....14.....16......20
32 15.43 18.70 20.35 22.47 06.01 07.77 11.83
(pressing the submit button, hold your thumbs!)
Old 09-05-2005, 05:31 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
hummmm, very interesting.
Since it doesn't happen at any other angle, I shall suggest that you are the proud discoverer of a glitch. It almost certainly shouldn't happen in real life, assuming the same set of sails. If I were you I'd get it to do it again with less percious input data and send the whole lot to tech support.
Alternatively, you can add 18 degrees to those that are too small to make them look right <grins> but personally I'd take it up with tech support.
Cheers,
Tim B.
Old 09-05-2005, 05:34 AM
nico nico is offline
Rep: 52 Posts: 186
Have a look at the FLAT and REEF values, (a few pages after heel values), and find out if the values are much lower.
Another thing you can look at, is to fix REEF at 1 (Opsets-> No reef)
____________
Nico
Vpp heel resistance idkfa Boat Design 2 09-20-2005 05:54 AM
Stability at low heel angles? Red at Night Sailboats 4 06-16-2005 06:59 AM
