#586
| I am an electrical engineer and I am never too surprised by the lack of real understanding people have of the physical world. I once got into a lengthy debate with 4 mechanical engineers that the torque through a slip coupling was conserved. (Maybe a very small allowance for windage on the coupling body) They could not figure out how I determined the power loss in the coupling simply by knowing the input power and speed from the the driving motor and the output speed of the driven fan. They wanted me to show them the power calculation for the fan because they figured power loss was input power less output power. It is of course but there is more than one way of arriving at the answer. So it takes a lot to surprise me when it comes to poor appreciation of the physical world by educated professionals. The problem with Mark's material is that it has not been peer reviewed (at least yet) and published in a respected journal or conference volume. Some of the self professed experts that visit here require this as they do not have the ability to understand mathematical information provided. I am sure some turn off as soon as they see an algebraic equation. I do not mind this but then they do not bother to seek understanding; just continue to offer an illfounded opinion. Rick W |
#587
(Although from Guillermo's perspective propellers can never exceed the velocity of the fluid they are operating in. Someone needs to tell all those boats and planes that move through fluids faster than the fluid using a propeller that they are not obeying Guillermo's law of fluid dynamics.) Rick W |
#588
#589
| Your approach is very similar to one that JB has used. I've used a number of approaches that I consider essentially bulletproof. The problem seems to be that many sceptics start with the conclusion that DDWFTTW is impossible, and measure all evidence relative to that assumption. Many of them simply will not engage. |
#590
Cheers.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
#591
When the helicopter is descending rapidly, the air is passing through the rotor disk from bottom to top. However, the rotor decelerates the air, so that again the force is in the upward direction. In between is the vortex ring state, obtained when the helicopter is descending moderately slowly. The air moves up through the rotor disk in the center, and down through the rotor disk toward the edge. Accompanied by turbulence and ineffective production of lift. But lifting nonetheless. The Bauer machine just starting is like the autorotating helicopter. The air is moving from the back of the rotor to the front. The drag moves the machine forward, and the wheels apply torque to the rotor. However, there may be a positive aerodynamic torque from the autorotating rotor as well. If the torque from the wheels is greater than the aerodynamic torque, then the wheels can be said to be powering the rotor. If the aerodynamic torque is greater than the torque from the wheels, then the rotor may actually be powering the wheels. But the difference is really not very significant because the rotor is still producing forward thrust in either case. The aerodynamic torque comes from the fact that the lift vector is tilted forward relative to the blade chord, just like that of a glider whose descending trajectory tilts its lift vector forward and opposes the horizontal component of its drag. As the Bauer machine picks up speed, it is like a helicopter pulling out of a vertical autorotating descent. Power is applied to the rotor and its velocity slows relative to the air, and then reverses. The vortex ring state forms and then shrinks toward the hub as more of the air flows from front to back through the rotor, until the air is flowing from front to back all along the rotor disk. Initially, this will be due to the induced velocity from the rotor's thrust as the machine has not quite yet reached the freestream wind velocity. Some parts of the inner disk may be producing an autorotating torque, but the outer portions are not, requiring the application of external power to keep the rotor turning. The wheels are powering the rotor by this point and the rotor can no longer be viewed as a windmill, if it ever was. But as the machine continues to accelerate, it reaches and exceeds the velocity of the air, like a helicopter that finally starts to gain altitude. Now the velocity through the rotor disk is the sum of the machine's relative wind and the induced velocity. There is no doubt at this point that it is the wheels that are powering the rotor and not the other way around, because the lift vector, which is perpendicular to the vector sum of the rotational speed and the inflow, is tilted back and has a component in the plane of the disk that would retard the blade if it were not for the torque being applied at the hub. Throughout, thrust from the rotor keeps the machine moving forward. Only in the beginning can the torque to the wheels be adding to the rotor thrust. As the craft accelerates, the wheel torque lessens and then reverses, acting as a drag on the vehicle. But as long as the thrust is greater than the sum of the aerodynamic drag and the drag from the wheels, the craft will accelerate. Eventually, the velocity through the rotor disk will become so high that the lift vector will be tilted back too far and the aerodynamic drag of the rotor will acquire a backward (upwind) component, and the thrust will drop off. When the thrust matches the drag from the wheels, the craft will have achieved steady-state operation. Power is a tricky thing to work out for any sailing craft, because the power available changes. Power is thrust times velocity, so at rest the thrust horsepower is zero, even though the thrust is not. As the yacht accelerates, the thrust horsepower increases because the thrust increases as the rotor becomes more efficient (especially if the pitch is fixed), and because the velocity is increasing. As the thrust starts to drop, power still increases, but more slowly. (Just like the peak power occurs at a higher rpm than the peak torque of your car's engine.) But the power extracted by the wheels is also increasing because of both the increasing torque demands of the rotor and the higher speed of the machine. Eventually, the two curves come together, and the power balance is achieved at steady state. Either the energy flows (power) or force & moment sums can be used to calculate what's happening, but as a practical matter, it's easier to use the forces & moments. So while a landyacht is like a fixed wing glider soaring in a thermal, the Bauer machine is like a helicopter, powered by the transmission from the wheels.
#592
| Tom, what you say about the Bauer cart is true if we know that he was able to actually reverse his prop pitch. We can see from the pictures that he can adjust prop pitch, but I'm not sure if anyone knows whether it can be reversed. If not, then the wheels always apply the torque that turns the propeller. This is the case with the carts we've built. The prop pitch is fixed, but they still self start without any trouble. |
#593
You are correct about the pitch. It has to be quite aggressive such that for each revolution it wants to travel further than the cart can travel. Thus the blades have a large pitch angle compared with those of a helicopter. It is by virtue of the mechanical advantage being in favour of the wheels that the cart goes downwind. If the rotor pitch is is less than the distance the vehicle travels in one revolution of the rotor then the rotor becomes a turbine and the vehicle goes upwind with the turbine torque overcoming the opposing torque from the wheels. The direction of travel relative to the direction of wind over the ground is based on what has mechanical advantage. Actually I have noted that in the road test video of your cart there is a very small reverse snap of the prop before it starts to power forward. This is not evident in the fan from behind test. I was wondering if there was backlash in the gears or if it actually caused the wheels to skid. Rick W |
#594
#595
| spork You are correct. I have it reversed. For the cart I detailed in the DDWFTTW thread, post #31, the prop would be advancing at 2.7m/s if in an unloaded state when the vehicle is doing 5m/s. This is the zero apparent wind condition but the actual airflow through the disc is 2.3m/s. This is for the 3.5m asymmetric foil. Rick W |
#596
| Guillermo: Will you please make comment on my posts. I understand that you don't like Rick's posts, but I have done nothing to offend you, and have provided the information you requested, but receive no response? |
#597
Don't take it personally Rob. That's his M.O. I've also tried to engage him in a discussion to reach a genuine understanding, as has JB. Good luck. |
#598
| I know, but I had to give it "one last shot" ... just hate giving up on people who've shown promise elsewhere. |
#599
| Rick, your description of faster-than-the-wind sailing directly downwind still sounds like perpetual motion to me. I'll have to go back and revise my understanding of the Second Law of Thermodynamics. There is no flow through the water turbine until the wind starts to push the craft downwind - partly through drag on the whole structure and partly through work done on the wind turbine - how does the system switch over from being air-driven to water-driven? The wheel-driven land system is the same - what drives the wheels? I'll sleep on it and come back tomorrow with a rigorous analysis. |
#600
First one is in the attached slide. The questions you need to answer are: 1. Will this vehicle actually work? 2. Are the numbers realistic for a vehicle weighing 20kg? Rick W |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| The Wind Powered Sail-less Boat | DuncanRox | Stability | 6 | 01-01-2009 12:47 AM |
| True wind/apparent wind? | pygmalion | Boat Design | 5 | 12-09-2004 07:52 AM |
| How close to the wind can a boat sail? | tonyr | Sailboats | 13 | 06-13-2004 08:35 PM |
| Sail horsepower vs wind force? | tommc | Sailboats | 3 | 02-15-2004 02:49 PM |
