Rick, what you provide in #468 is just fine, but it's not what G asked for. He specifies a bizarre analysis of a control volume in the transient case where the vehicle begins at rest within the volume and exits the volume at greater than wind speed. He says he wants the energy flux at the inlet and exit of that volume as a function of time.
The problem with this is that to truly provide what he requests would be quite a task, and the results would be of no use in proving viability of DDWFTTW.
Whether he's simply yanking our chains isn't clear to me yet. But I have to agree he's pretty quick to dismiss all valid analyses and unwilling to even tell us where he feels they go wrong. He's also completely unwilling to offer us an example of the type of analysis he demands on the simple case of a sailboat on a typical course of sail.
I believe I provided exactly what he asked for in his post #462. I certainly gave him the proof he asked for.
For the said boat with 9m prop and 800mm turbine moving through the water at 3.5m/s with wind speed at 3.5m/s the energy balance over one second is:
Air Stream and Propeller
The air immediately ahead of the boat is moving at 3.5m/s. In 1 second 1.3m of air is drawn into the prop to be slowed to 2.2m/s immediately behind the prop.
Ma = pi x 4.5^2 x 1.2 x 1.3 =101kg
Reduction in air energy in going from 3.5m/s to 2.2m/s:
Ea = 1/2 x 101 x (3.5^2 - 2.2^2) = 374J
Work done on the air by the propeller to accelerate it rearwards at 1.3m/s:
Eaw= 1/2 x 101 x 1.3^2 = 86J
Turbine
The water immediately ahead of the turbine is at rest while behind the turbine it will be moving at 0.01m/s. In one second 3.49m of water will have passed through the turbine.
Mw = pi x 0.4^2 x 1000 x 3.49 = 1754kg
Energy imparted to water:
Ew = 1/2 x 1754 x (3.5 - 3.49)^2 = 0.09J
Boat
Work done in one second to overcome the boat drag of 20N moving at 3.5m/s is:
Eb = 20 x 3.5 = 70J
The system has so far unaccounted losses as follows:
Transmission Eml = 2.7J
Propeller Epl= 195J
Turbine Etl = 8.9J
The propeller and turbine losses produce swirl and turbulence in their respective fluids as does the net flow through the discs eventually.
The energy ballance over 1 second is:
Net Energy = Ea - Eaw - Epl - Etl - Ew - Eb - Eml
= 374 - 86 - 195 - 8.9 - 0.09 - 70 - 2.7
= 11.3J
There is net energy of 11J available in each second at the Vb = Vw condition to continue to accelerate the boat.
ABSOLUTELY NO DOUBT THAT IT CAN EXCEED THE WIND SPEED DIRECTLY DOWN WIND!!!!!!!!!
Rick W
