| Wind Boundary Layer & Effective Reynolds Number? Happy New Year Everybody, It is common knowledge that under 6 knots true wind speed, the wind is laminar above the water and above this wind speed, the boundary layer of the wind above the sea is turbulent. The question is: With wind speed above 6knots, is the actual Reynolds number on a sail different (higher) from theorical Reynolds number computed with the classic equation ? Thanks in advance Regards EK |
| This is outside my domain. If no-one here can answer, how about trying to contact the Wolfson Unit at the University of Southampton, UK. |
| I didn't quite understand what do you mean when you make a distinction between the "actual" and "theoretical" Reynolds number. And what is the "classical equation" you mention? If it is the equation which defines the Reynolds number: Re = (rho*V*L)/viscosity then the answer is NO. The velocity "V" which appears in the equation is the mean (time-averaged) far-field velocity. In case of steady laminar wind it is the actual wind velocity. In case of turbulent wind it is a statistic mean velocity, stripped off the fluctuating velocity components u, v, w (in x, y, and z direction respectively). So when you say "6 knots", you are talking about the mean flow velocity, which is the one used to define the Reynolds number. The problem arises if you have a test data for your sail, obtained through measurements in a flow with some given level of turbulence. If you try to use it to calculate the sail performance in an airflow having a different turbulence scale, then you will introduce some (a priori unknown) degree of error. It happens because the different turbulence levels in the airflow ahead of the sail (far-field flow) will modify the laminar-to-tubulent transition characteristics of the flow around the sail surface and also will modify the point of boundary layer separation (wake formation). If it all sounds tricky, that's because it is tricky. ![]() |
| Thank You Daiquiri It is exactly the answer I was looking for: In other words I was suspecting that the turbulent flow of the wind will modify the point where the transition occurs. (earlier with turbulent airflow) By the way, I was guessing that for higher speeds above transition, the turbulence of the airflow would increase the "effective Reynolds Number, decreasing the friction coefficient accordingly. My idea was to achieve an appraisal of what you have defined as a " degree of error", I didn't know it was so tricky . Thank you again and good winds for the new Year Erwan |
Remains the problem of the boundary layer separation and stall angle, which will also be modified with wind turbulence. Unfortunately, there is very little freely available test data about sail aerodynamics. If you are not involved in some America Cup design team or in some specific academic research programme, you have to fight your way through a stringent literature found in internet or in some of very rare (and mostly obsolete) books dealing with this topic. By the way, even people who work in A. Cup (with all the money and facilities thay can rely upon) have a nice amount of problems and uncertainities when they have to translate the wind-tunnel measurements data to a real-size boat... ![]() |
| Thank you both for tempting me to start digging around for free papers currently available on sail aerodynamics, and even for the abstracts of subscription material. I may even be tempted to fork out the odd 10 Euros to buy some of it. What is the purpose of your research, Erwan? |
| Forgotten Assumption Thank You Daiquiri for taking time to answer. I forgot to mention that the subject of my "research" is the A-Cat rig, any kind of ring, including wingsail. So that is why I though it was important to have an idea about what I improperly defined as "Effective Reynolds Number". |
Sails with sleeve-luffs, like windsurf sails, probably have a minor region of laminar flow at the leading edge too, but it depends very much on how the sleeves are made (sleeve material, shape and extension, mast shape etc.). |
| Foil section at low Reynolds numbers. | whaletail38 | Sailboats | 6 | 09-21-2008 02:27 AM |
| effective plating | eduard | Class Societies | 6 | 11-13-2007 03:42 AM |
| reynolds number for a main acted on by a jib | Paul Scott | Sailboats | 8 | 05-29-2007 11:26 AM |
| Reynolds Aluminum Boat | timkay2 | Metal Boat Building | 1 | 08-08-2005 12:50 PM |
| True wind/apparent wind? | pygmalion | Boat Design | 5 | 12-09-2004 06:52 AM |
