| Will this work? This is evidently a monohull cut down the middle and converted into a catamaran. I'm looking for more speed more stability and lot's more room on deck. It is 8m50 long by 5m wide and has two 100hp diesels. Geoff |
| Assymetric catamarans do work, though simply cutting a monohull in half will actually increase the power required to drive it at a given speed. It will be more stable (due to the increase in beam), though it might not be as comfortable. If you want a catamaran, I'd suggest you went to a multi-hull designer. Tim B.
| Dunno about those inboard props in the pockets. All the cats I have seen had an outdrive of some flavor. Ask whoever supplied this plan if anybody else has built and tried it. Kelly Cook |
| The boat is intended for professional fishermen, hence the drive shafts. What I am trying to do is use my existing molds to make a new boat, to save costs. |
| Cat Hull Design Hi Geoff, Have you looked at the Corsair Cat-hulled foiler site? http://www.corsairmarine.com/0FoilerIndex.htm With the exception of the inboard engines and minor changes in the shape aft to accomodate the props, it would seem this would be a good jumping-off spot that would require only small changes to the existing tooling. Chris |
| I do understand the preference for shaft props for fishing. My concern is how successful the pockets would be when applied to a cat type bottom. Has anybody out there seen a cat configuration like this before? Kelly |
| Will this work? | millrtim247 | Boat Design | 25 | 02-24-2006 11:00 PM |
| will this work | newbie | Boatbuilding | 3 | 02-17-2006 03:52 PM |
| Will this work? | usa2 | Sailboats | 17 | 12-02-2005 05:35 PM |
| interior design work experience/work wanted | schwing | Services & Employment | 1 | 01-19-2005 12:52 AM |
| any work please | nzealand | Boat Design | 0 | 09-16-2004 08:59 PM |
