| Will a set of running strakes help eliminate bow steer repowered an older 46' Hatteras and she now cruises 26 knots. very stable and comfortable. in a following sea she runs over the top nicely but will occasionally bow steer due to the steep forefoot. if i install a set of strakes midway between the waterline and the keel, approx. 18 feet long and 1.5 inches wide parallel to the water, would it provide enough lift to help mitigate the bow steer or do you think it is a waste of time?? would it adversely affect head sea comfort?? thanks |
| Strakes on your boat wouldn't amount to much. The bow is just being driven down, by following seas lifting the fat stern, plus it's depth isn't helping much either. Throttle back and find the sweet spot, possably on a jibing course. |
| That is typical behaviour for a Carolina boat if you try to surf. The solution is to slow down.
__________________ Gonzo |
| bow steer in fast powerboats | gtflash | Powerboats | 11 | 10-20-2010 06:04 PM |
| Best thru hull design to keep a gen set running at over 40kntsu Hulls | ChrisN67 | Boat Design | 18 | 07-07-2010 10:12 PM |
| Hard to steer to starboard | 7228sedan | Inboards | 13 | 06-21-2010 07:18 AM |
| Commander Hawke Bow Steer | Joe Surgenor | Powerboats | 1 | 08-29-2007 08:33 PM |
| Sportfisher Running Strakes | altim | Boat Design | 0 | 07-21-2005 02:48 AM |
