Old 03-12-2005, 04:30 AM
JimCooper JimCooper is offline
Rep: 10 Posts: 81
Will this heavy boat work to windward ?
To the naval archtects and marinel engrs and those in the know
I hope I have attached some pictures here of a sail boat.
Do you think she would be a good sea boat ? 50 feet long 30 tons. Lots of sail area.
Would she work to windward in a gale with a total draft of 1 fathom?
I am looking for a friend of mine, if he doesn't I might.
Thanks
James
Will this heavy boat work to windward ?-photo-1a.jpg  Will this heavy boat work to windward ?-bottm.jpg  Will this heavy boat work to windward ?-boat.jpg
Old 03-12-2005, 05:54 AM
Rep: 700 Posts: 3,208
The simple "rule of thumb" for conventional full keel boats is the draft should be more than 1/7 of the LWL.
So on this boat if the LWL is about 42 ft ,,7 x 6 (("one fathom")) is about 42 and you should be OK with out help like a center board.
Most likely a cruiser would assist with the engine ticking over at 1200 to give better windward ability , but its NOT necessary, just helpfull.
Working out in a storm will mostly depend on weather the correct sails are aboard, not underbody shape or area.
A Storm trysail and storm staysail works far better than a heavly reefed main and usually useless roller furled sail 1/10 unrolled.
FAST FRED
Old 03-12-2005, 03:17 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
It looks like steel, if it is, you can always add "leeboards" or fins of sorts as long as the sail plan is OK.
May the wind blow briskly in your sails!
Old 03-12-2005, 04:34 PM
Rep: 1623 Posts: 2,344
Jim
Change the single plate rudder to a double plate with a decent foil section, you may want to add a bit of depth to the keel.
This is a NZ Woollacot design, more common in this part of the world. I think you will find she used to be a centre boarder and has had a long deep shoe added already to the keel.
Try and find someone who sailed her in a gale, can be hard I know, but since she has been modified she may not stand up to her sail enough to work to winward in heavy weather.
Mike Johns.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 07:54 AM
Chesapeake bay work boat????? localwaterboy Wooden Boat Building and Restoration 50 02-22-2006 09:16 AM
Has anyone here started a boat building business from scratch? aqualoco Fiberglass and Composite Boat Building 61 09-27-2005 01:18 PM
building polyethilene boat gesdim Fiberglass and Composite Boat Building 0 01-09-2005 09:50 AM
