Old 10-18-2005, 06:00 PM
txslowpoke txslowpoke is offline
Rep: 10 Posts: 2
Wide jon boat plans?
I am new to this, have been searching the net with no results. I am wanting to build a flat bottom jon boat,14' or so length and about 5' wide on the bottom. Aluminum new ones 14'x56" wide are 3 grand$$. Any ideas where to find plans for wide jon boat. Thanks
Old 10-18-2005, 07:29 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
I assume you will use Home Depot or Lowes, EXTERIOR plywood AC sides, for all of it and 2 coats of paint? ---What is the finished price range for the boat only?
Old 10-18-2005, 07:51 PM
Do a web search using this----JON boat plans---- #1, Uncle Johns plans of his look great! Post back. If scarfing is not what you feel comfortable doing. Butt blocking the pieces together under a seat will work and not show. This site has some VERY experienced wood hull builders.--------------------------------- Pick a plan you would like to build and ask them for a opinion BEFORE you buy.
Old 10-18-2005, 09:18 PM
Rep: 10 Posts: 2
I HAVE done the jon boat search many times over. Hence my posting here. Personally 3k$ is high for a boat this simple, here is a place I found on the net I thought I could ask a question.
Now if all I wanted to was throw some plywood together and a couple coats of paint on and go FER it i would not have posted here.
thx.
Old 10-18-2005, 09:42 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
http://angelfire.com/ego/lewisboatworks
http://duckworksmagazine.com/05/desi...ljon/index.cfm
Steve
Carolina style boat plans woody Wooden Boat Building and Restoration 9 11-06-2009 06:57 PM
Lobster Boat / Downeaster Plans Wanted Paul Dean Boat Design 10 05-31-2005 09:55 PM
Aluminum Drift Boat Plans?? Other than Glen-L Finman Boatbuilding 14 07-12-2004 09:56 PM
Wooden boat plans conversion swb Fiberglass and Composite Boat Building 1 06-16-2004 07:08 AM
Building a 15'6" jon boat - what should i be aware of? Unregistered Boatbuilding 2 01-25-2004 05:20 PM
