#136
This latest iteration of your foils would still be luffing. I don't think I will ever understand what you are trying to show. |
#137
Next you will mention Mari Cha? Specialty boats. In the 15 years since EM was launched, how many have followed? Let's see how this boat would stack up against a TP52. Upwind there would be no contest. |
#138
| Paul Then perhaps ive missed the question/point you're asking? sorry! |
#139
To get the true angle of the wind you need to be removed from the infuence of the sails Attached shows a foil of 1% thickness, with 10% camber located at 30% chord and an AR of 4. It is aligned to the position of maximum lift. You can see from the streamlines that the air has curved quite a lot as it enters the sail. This is not the true apparent wind. The second image is the same sail but zoomed out to show that the flow is directly left to right. The sheeting angle with respect to the apparent wind is about 15 degrees. The sheeting angle would be much greater for the wind angle approaching the front of the sail. So the angles you experience depend on your frame of reference. There is no instrument using wind data around the boat that can give you the far field apparent wind. You would need to be collecting wind data from a fixed point and then adjusting to the actual velocity vectors to determine the far field apparent wind. All the angles I have shown above refer to the far field and this is taking undisturbed airflow directly left to right. So sheeting angles with respect to apparent wind need to consider the frame of reference of the observer. Rick W |
#140
| Yawl Enthusiast! Last week I sailed on board http://www.sailingnetworks.com/boats/view/2 in the photo she has four sails up. But we also used the Mizzen Stay Sail as well. The sloop designs were quicker in light air. They are lighter and have longer keels. On the light air days we came in around the middle of the finishing order. But on the two days when the winds were over twenty knots constantly we lead the field, being able to put up five sails and avoid broaching! My money is on yawls!
__________________ By Chris author boatpride.com Virtual sailing resources and products, an interactive, multi media experience! Leave a video / audio /written comment! |
#141
| Rivival I was just reviewing a few subject threads, and ran through all of this one real quick. There was much really good conversation here. I thought it desired reviving. |
| Ideas for 32' Yawl | milljfred | Fiberglass and Composite Boat Building | 0 | 04-15-2009 01:30 AM |
| Rig handling: Cat Ketch, Cat Schooner, Sloop, Cutter | Seafarer24 | Sailboats | 8 | 05-30-2006 11:06 AM |
| Caledonia Yawl | sailormantrader | Sailboats | 0 | 12-16-2004 01:27 PM |
| Caledonia Yawl | sailormantrader | Marketplace | 0 | 12-16-2004 01:24 PM |
| converting sloop to ketch? | tim mcd | Boat Design | 4 | 02-22-2002 04:43 PM |
