  #31
Old 10-01-2005, 07:29 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
If you want to plane, you want as little drag as possible pulling you back. You also want as much lift as possible pushing you up. On most planing powerboats the bottom actually slopes down right up to the transom, usually about -5 deg., and so you get some lifting force at the stern. You then have a sharp corner so the boat and water can break away while maintaining more-or-less laminar flow right up to the transom. Curving the transom double-ender style works well at low speed, where laminar (smooth) flow can be maintained right up to the transom. But try to plane such a hull, and you get massive turbulence developing under the stern as the water tries to keep in contact with a boat that is moving faster than the water can adjust. Turbulence then prevents the hull from lifting and so it can't plane easily.
In general, the trailing edge should be sharper the higher the speed. (Note that this refers to the trailing edge of the hull-water interface; ie. the corner between the transom and bottom as viewed in profile.)
  #32
Old 10-01-2005, 08:09 PM
kudu kudu is offline
Rep: 10 Posts: 112
But in the scheme of things...Really now...How much of an issue is that mini wave at the stern of a double ender sail boat fully loaded for blue water sailing?
It's becoming apparent that this thread has hit a "Y" in the road...Speed and efficency vs safety and good looks....
  #33
Old 10-01-2005, 08:22 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
A day in the life...
Hello...
Got back from a sail in my 'fatass'...
Here in Vancouver you 'reach out and run back' - I many times would like try a sail in a double ender over my boat when running wing on wing with a pole out on the jib - going home...
With the tide aft and running in with me - I cannot pour a whiskey without fear of a wild and crazy broach - bah...
Mind the boom...
My next boat will have two 'pointy ends' - and a pilot house against the damned rain...
Yup....
SH.
  #34
Old 10-01-2005, 08:48 PM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
My next boat will have two 'pointy ends' - and a pilot house against the damned rain...SH.
That's because you're drinking whiskey with an (e). Either US, Canadian, or Irish...That stuff is only used for priming kerosine engines or curing worms in cattle. What you drink is whisky, preferably a single malt.
  #35
Old 10-01-2005, 08:49 PM
Bergalia's Avatar
who's right who's wrong ?
  #36
Old 10-01-2005, 08:54 PM
Rep: 10 Posts: 112
Hello...
Mind the boom...
Yup....
SH.
I just listed plans on this web site for a double ender with a pilothouse. They're for a 50 footer. Interested?
  #37
Old 10-01-2005, 09:50 PM
Skippy Skippy is offline
Rep: 12 Posts: 568
kudu: How much of an issue is that mini wave at the stern of a double ender sail boat fully loaded for blue water sailing?
When you're broad reaching in a nice fresh ocean breeze, it should make plenty of difference. But zipping along in perfect conditions is the least of your worries when cruising. I wonder if keeping that max speed down might reduce the chances of broaching?
  #38
Old 10-01-2005, 11:56 PM
You gots to have purpose...
Hello...
I don't drive a NASCAR to work and I don't run my Geo Metro on the track on weekends...
Form follows function - necessity is the mother of invention - glass is good if you need to look through it - all that stuff...
I think the one we need here is - 'play the game by averages'...
You can build the 'perfect' boat - the 'perfect' race car - but you cant guess at what (G)od is going to throw at you on any given day - or for a month at sea...
So that said - I like designs for average conditions with creature comforts for those less than good conditions...
Maybe thats why I stay married - and drink whiskEy...
SH.
  #39
Old 10-02-2005, 03:12 AM
Rep: 1623 Posts: 2,343
A few comments here.
Latest research has shown the submerged transom to give lower drag BUT it depends on other factors in the UW hull form too mainly how the UW aft lines run.
Transoms that are entirely above the WL are essentially double ended hulls but the topside run aft gives a lot more usable space and counters one problem with pointed sterns, which is pooping in a following sea due to lack of reserve bouyancy.
Modern heavy weather tactics have changed with a quarter presented to the following sea and the hull allowed to run free rather than stern-to with warps and drogues to slow the boat down. Under these tactics a double ender has only the disadvatage of a lower bouyancy aft.
Another problem can be the hobby-horsing tendancy with similar sections fore n aft. Flatter aft sections damp the pitching oscillation better.
I have trouble with the loss of a decent cockpit or aft cabin with boats with a pinched stern, I favour a small transom to a true double ender any day.
Mike Johns.
  #40
Old 10-02-2005, 03:14 AM
Bergalia's Avatar
- I like designs for average conditions with creature comforts ...... - and drink whiskEy... SH.
Honestly...the man is incorrigible, even for a Canadian...do we decent chaps want to share a page with a man who boasts such uncivilised drinking habits...
  #41
Old 10-02-2005, 03:44 PM
Rep: 10 Posts: 112
You are a very humorous guy, Bergalia...I enjoy your input
  #42
Old 12-03-2011, 04:43 PM
tunnels tunnels is offline
old one !
Rep: 343 Posts: 1,519
Originally Posted by kudu View Post
This comment puzzles me...Does it really matter that the water from both sides of the hull crashes into each other? It seems, at that point of interference the transom would be one step ahead of it, no?
You dont see what is happening before the water leaves the bottom of the hull ,there lots going on as the hull moves through the water unable to be seen but its there . trail colored cotton thread throught the water that extends along and round and past a shape traveling through the water and see where the water actually starts to separate to go round a shape and what is happenig even up to a meter past the trailing end ! movment is still happening way behind the boat . its all interconnected and inter-related !. its what we cant see that we dont understand and just guess at and most time get it completely cocked up and wrong .
Just remember it takes energy to move water !! a object moving through water is separrating and pushing aside the water to move forward and as it gets past the widest point the water presure +energy is pressing backinto fill the void being left behind as the hull moves forward through the water . this presure is taking place a long way fro the actual hull as well not only up close but up to a couple of meters away look at the wave alongside the hull as it moves !! the wave is water pressure up is pressure down is suction so take notice nexttime you see a boat going through the water . same applys to air with two cars passing at high speed they push eaach other aside and then immediatly draw each other into the other slipstream behind is more notice able in two highspeed trains traveling in opposite dirrections in a tunnel . theres high pressure before and suction after . water is fluid air just a lot more dense !
Making beautiful boats is a passion never a chore !
  #43
Old 12-03-2011, 05:01 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1782 Posts: 2,984
Making boats is a[l]ways a passion never a chore!
I couldn't agree more.
Thanks for bringing this old discussion to light!
Hoyt
Lighting is very selective and will not strike crap. Wynand N
http://www.genocidewatch.org/southafrica.html http://www.saabc.net/
  #44
Old 12-03-2011, 06:21 PM
Yobarnacle's Avatar
Yobarnacle Yobarnacle is offline
Rep: 403 Posts: 411
aged sour mash...straight. smoothe with an E
  #45
Old 12-03-2011, 06:29 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Originally Posted by MikeJohns View Post
........ Under these tactics a double ender has only the disadvatage of a lower bouyancy aft.
Surely this depends on whether
A) a canoe stern is a square transom with the edges cut off,
B) a transom with the hull extended out further
If it is A, then the hobby horsing is 'more', if it is B, then it is even 'less'
I like canoe sterns when a huge wave is chasing in behind you across the harbour bar.
I like square sterns when I am lounging around in the sun with friends, and there is more room on the end of the boat, while paying less at the marina per foot.
I hate canoe sterns when I have to build extra framing at both ends, and bend the timber at both ends, and paint/epoxy the narrow bits on the inside at both ends.
I hate canoe sterns when trying to hang a dinghy or an outboard motors of the end of the boat, or trying to climb in from the water.
So, I definitely prefer flat sterns unless canoe sterns are better - I think.
Plane a double ender Inquisitor Powerboats 21 06-22-2010 05:40 AM
Is there validity to the notion that a pointy stern, a canoe stern, is safer at sea saltydog123 Sailboats 27 04-01-2009 04:20 AM
Colin Archer double ender designs? Mohan Pakkurti Boat Design 16 03-01-2009 08:10 PM
Double ender on a Crusing Cat fburton Boat Design 10 09-16-2005 11:44 AM
38' Atkin design 'INGRID'(double ender) hull layup Ian MacFarlane Materials 5 07-10-2004 09:29 AM
