Old 12-13-2009, 06:44 PM
Gashmore Gashmore is offline
Rep: 58 Posts: 52
Who's better Skene, Gutelle or Larsson & Elliasson?
I have been working on a spreadsheet to calculate shroud loads on my 2 spreader continuous rig. I have Skene's long method and the NBS from Larsson & Eliason set up and just added Gutelle.
Comparing Skene to NBS Skene is about 8% over on the lowers, right on with the intermediate and about 5% over on the cap. That is a fairly comfortable range that I can live with given the different approaches. Comparing Gutelle to NBS however Gutelle is 5% low on the lowers and intermediates and almost 15% low on the cap. I dug out Gedes' spreadsheet from back in '01 and get almost the same numbers as Gutelle.
My quandary is that I am rigging in Dynex Dux so my choices are 9mm and 11mm for the cap shroud. If I go with the Gutelle numbers I can use 9mm. Skene and NBS say 11mm.
Old 12-13-2009, 07:14 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Sorry, I have only read Skene, but given that his weights are slightly higher leads one to believe you have a higher margin for safety against failure of the rigging.
Hoyt
Old 12-14-2009, 07:09 AM
Greybarn Greybarn is offline
Rep: 10 Posts: 57
You may want to check the stretch of your "synthetic" shrouds against rod or wire. I thought that the "synthetics" usually get sized for the stretch while rod or wire are sized for breaking strength.
Old 12-14-2009, 08:48 AM
Rep: 58 Posts: 52
Actually the creep rate is critical rather than stretch and therein lies the problem. If I design for creep using Gutelle 9mm will be just under the creep limit and the stretch rate will give the mast a nice even bend to leeward. Using Skene 11mm is required to control creep but the stretch is so low that, should Gutelle actually be correct, the mast makes an S curve with the top section bending to windward.
Old 12-14-2009, 09:41 AM
dskira dskira is offline
Rep: 1305 Posts: 1,372
I had the chance to know Gutelle. A great man. He was living in Paris, and it is on the same trip I went to see Uffa Fox, also living the winter in Paris.
Pierre Gutelle was a very shy man, with a great talent, and an eye to understand the plywood constrution.
The three books are very different, depending the kind of boat you want to design.
But the best is to have your own desision and take the book just as a guidance.
Lloyd's will still the reference anyway.
As for the rigging the Euler method, is used by all. And from that you can choose the different opinions.
In matter of boat rigging, we still in a grey area, since we can't rely on static calculation. One day the boat sail by force 1, and other time in a tropical storm.
Uffa Fox method: The shroud should be on one side enough to lift the boat. Period. It worked very fine, and took one minute of research for the right cable. Double the diameter of the shroud for the turnebukle and you are in business.
Cheers
Daniel
Old 12-14-2009, 10:01 PM
Rep: 3125 Posts: 9,398
Interesting, I use a similar, simple formula for cruisers, which is a multiplier of the boat's full up displacement.
Old 12-16-2009, 10:40 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
PAR...Question:
I recently came into possession of a 200+ ft roll of 7x19 316L stainless 3/16" wire rope...Off the top of your head, what general size boat Length or displacement or both would use this sized wire as standing rigging? Or perhaps more appropriately...mast height and SF. I am sure it is larger than anything I would contemplate but just to give me an Idea.
Old 12-16-2009, 11:09 AM
Rep: 10 Posts: 57
On the 29 foot sailboat we build (about 4,400 lbs lightship with 1,958 pounds of ballast) we use 1/4" 1x19 SS wire for the side shrouds and headstay. This is on a 1 spreader, fractionally rigged mast. We could maybe use 3/16" for lower but it is borderline on being too stretchy. Something like a Dragon, Etchells or Atlantic use 3/16" wire.
Old 12-16-2009, 11:31 AM
Originally Posted by lewisboats View Post
PAR...Question:
4000 lbs
Old 12-16-2009, 11:35 PM
Close enough Daniel.
Steve, you will not see this on more then a boat in the Catalina 22 class (a fat ton). Even though it's breaking strength is around 4,000 lbs. you could exceed this pretty easily on a 3,000 lb. boat in a pitching sea. Of course it would be nice if this was the weak leak, but it's usually not and typically a much smaller part, like a screw head, tang hole or clevis.
Nice find, you wouldn't happen to need to mail it to central Florida for winter storage would you?
Old 12-17-2009, 11:21 AM
lewisboats's Avatar
Obsessed Member
Sure...the wire gets a tan and I freeze my gronicles off. Nope...it'll have to endure the cold j u s t like Me. Thanks for the info tho folks...I just might end up having a use for it...eventually.
Old 12-17-2009, 03:15 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Lewisboats, time for a summer holiday.
Yes, you can now take a nice healthy tan take back home.
SA is just the place for you to visit.
First class accomodation in true african style.
Our well-trained staff is always available to ensure that your stay is as comfortable as possible.
Your hosts has been in the business for years and their hospitality is without comparison.
Personal attention to detail will ensure a memorable stay.
Bring that figgin wire rope with.
It's going to get stolen if you leave it there...
Regards
Fanie
Water ! Just gimme water !
Old 12-18-2009, 10:08 AM
lewisboats's Avatar
Obsessed Member
Too bad I'd have to sell the rope...clunker cars...house...kids and precious boat building tools just to afford the trip. I would certainly love to visit someday tho.
Suppose we should get back on topic or the original poster is going to get a little hot me thinks.
Old 12-18-2009, 10:43 AM
Rep: 58 Posts: 52
s'OK. I'm sitting here in Georgia freezing and wondering if anyone in SA needs a boat delivered to the Caribbean.
Old 12-18-2009, 12:20 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
I would only trust a method based on maximum righting moment of the boat in fully loaded condition.
Only shared knowledge can grow.
S&S34 Cruising speeds & equipment Steve Pereira Sailboats 3 12-11-2008 12:36 AM
QUESTION ABOUT 'PRINCIPLES OF YACHT DESIGN' by L. LARSSON EAP Stability 3 03-31-2007 06:25 PM
Larsson & Similitude Stephen Ditmore Boat Design 20 01-13-2005 07:11 AM
Larsson & Eliasson Rigging Calcs cgorton Sailboats 0 12-13-2004 11:17 AM
Calculation of the hull panel from Larsson Gades Boat Design 1 09-18-2002 04:42 PM
