Old 11-23-2006, 06:20 PM
Verytricky Verytricky is offline
Large Member
Rep: 400 Posts: 248
who can use software to build a design..
I can not.
I do have drawings though. I guess I could hire someone to create the CAD drawings for me if I gave them the design drawings I have?
Thoughts?
Old 11-23-2006, 09:33 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
Simple answer: Yes!
Old 11-23-2006, 11:36 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Simple job, depending on how far you want to go.
But, unless you want CNC files, why would you want them converted to CAD?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 11-24-2006, 02:55 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
CAD drawings (3D model) can simplify calculations of weight, stability, hydrostatics.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 11-24-2006, 05:46 AM
Large Member
Rep: 400 Posts: 248
OK, you guys are going to have to type slowly, so I can catch up. My idea of CAD ment it was on the computer. I race boats, not computers. I can logon to the internet and download pictures, and that is about as far as my graphics knowledge goes...
Essentially I want to be able to have a 'thing' which allows me to look at the boat and rotate it and see that it looks like it should look.
Later I would like to have a thing that lets me slice the boat up in to 32 slices lengthwise and about 8 slices width wise, so I could build a 5 foot model of it.
Right now I have drawn on paper 10 slices accross the width of the boat, and one slice from front to back in the middle. I can get these scanned and provide them as JPG files.
These could be enough to build a model, but I want to refine things first before I build the model. Once I have the idea finished, I then would like more slices to get a better picture.
Old 11-24-2006, 05:57 AM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
Are these 'slices' of a design you have done yourselve. If so, the slices across the boat and the one down the centre line would be enough to construct a 3D computer model of the boat.
I think you are over estimating the number of slices you will need to build a 5ft model, unless there are some really odd features on this boat.
Old 11-24-2006, 06:02 AM
Large Member
Rep: 400 Posts: 248
Yes, these slices are my own work.
I drew the profile of the boat to the best scale I could, then I placed my first 'slice' through the drivers head, then used that as the base template, and used tracing paper to work backwards, changing the shape the way I wanted, then did the same from the driver towards the front.
The anti stuff nose will be intricate.
The wings will also be intricate.
This is why I thought I would need more slices, as the current drawings dont show the picture in my brain.
Old 11-24-2006, 06:27 AM
Rep: 572 Posts: 635
If the design only really exists in your head, than transferring it to the computer is not really the next step. Somehow you will have to 'realise' it in some fashion on paper in a way that the computer driver will understand.
Or perhpas you will need to liaise with (employ) a designer to help with more of this process.
Have you got a book like John Teal's 'How to design a Boat' ? It is a pretty succinct description of how to represent a boat's shape on paper. The established methods work pretty well, and it sounds to me like you are trying to develop your own method for this.
Old 11-24-2006, 06:34 AM
Large Member
Rep: 400 Posts: 248
I will look into the book.
Alternately we do have some boat designers in the UK..
Old 11-24-2006, 06:53 AM
Rep: 572 Posts: 635
Is this for the June 2008 RBR? If so, what class had you got in mind?
Old 11-24-2006, 07:06 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
verytricky: "Essentially I want to be able to have a 'thing' which allows me to look at the boat and rotate it and see that it looks like it should look."
i have a "thing" ( choice of 4 secretary voices) that reads my e-mail but like speech, real time 3d viewing never really took off.
google did not answer what standard and when 3d viewing in their browser will be possible
acrobat now has for about 1000 some 3d posibility's in PDF and yes there are other 3d viewers but i found VRML the easyest free 3d viewer
never did much with VRML but if you like have a look after downloading the viewer and version converter
http://www.parallelgraphics.com/prod...load/iexplore/ for the free viewer
http://www.parallelgraphics.com/prod...rter/iexplore/ for the vesion converter
viewer is safe and wont tilt your pc, open the file than butterfly icon and permit explorer to read it, its a bumpy ride but works fine
for rotating a VRML 3d model the study and turnbuttons are easyest to start with also richtklick mouse, put on lichts or other scenes etc
most boatdesign programs have VRML export but god only knows why we never see more use of it
one more thing; if it looks like, quaks and walks like a duck it probably is
but we guy's can do more on our pc's so now show your drawings
got to run
Old 11-24-2006, 07:11 AM
Large Member
Rep: 400 Posts: 248
This boat is aimed towards some long distance record attempts in and around Europe. It would not be a regular race boat unless the 'HOTBOAT' series takes off. It has three crew, two driver stations side by side in front with full dual controls, and a naviguessor seat in the back behind the drivers.
RBR will not allow canopied boats.
As I will not go faster than 20 miles an hour without a canopy, I doubt that I will be taking part - short of the organisers realising they are being really stupid. Accidents happen, and in an enduro race like RBR people will be tired, people will make mistakes, the sea *will* get rough and accidents will occur, boats will rollover.
Hitting the sea at anything approaching a proper race speed = broken bones, head injuries and possibly death. Then we are talking rescue attempts to an injured crew, or body recovery.
Doing the same in a proper canopied boat = getting wet. Then rescuing yourself, as you are still able to do so.
But this is a whole another story.
It would be a wonderful RBR raceboat, but the canopy/safety cell will be an integral part of the design, and IMO the most critical component of the whole boat. Cutting the roof off as suggested by the RBR organisers is simply never going to happen.
Old 11-24-2006, 07:14 AM
Large Member
Rep: 400 Posts: 248
As always.....
( need a thumbs up emoticon here )
Old 11-24-2006, 07:24 AM
yipster's Avatar
i was merely complaining when a pc will make my caffee
Old 11-24-2006, 07:30 AM
Large Member
Rep: 400 Posts: 248
All English speaking PC's can already do so. It must be the Dutch ones at fault?
Do I need Yacht Design for what I want to build? Scottg Education 5 02-22-2006 10:17 PM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 12-31-2005 11:40 PM
Looking for the right path to design and build ben_morel Education 44 11-24-2005 03:51 PM
looking for a design to build samh Boatbuilding 1 01-18-2005 09:49 AM
How to build from a design. Guest Boatbuilding 6 12-06-2003 04:55 PM
