| Whats wrong with my calculations? What is the problem? One of the values we gathered from the towing test was at 1.85m/s, our boat experienced a 3.5N drag. Using this piece of information, i attempt to break down the 3.5N into frictional and residuary resistance using Rf = FSV^n for frictional, subtracting it from 3.5N would yield residuary. For residuary resistance, i believe i could use Residuary of actual boat/Residuary of model = (length of boat/length of model)^3 During towing, my model's displacement would be 330g(weight of the model without anything) + 480g(weight of loaded weights) at a draft of 3cm, the wetted surface area was 818cm^2. I then estimated the WSA of the actual size boat to be the square of the boat: model ratio which is 20:1. Ultimately, using FSV^n (actual boat) + (Residuary resistance model x 20^3) sheould give me a close estimate of what the actual size boat resistance would be.However, the frictional resistance i calculat ed for the model is too small to be true. L=length of boat=0.54m P=density of water=1000kg/m^3 F = (P/1000)(0.1392 + (0.2581/2.68+L)) Rf = FSV^n = 0.219 x 0.0818 x 1.85^1.825 =0.055N 0.055 is way to small... |
| What is Your boat's particulars? |
| Power catamaran model Length=0.54m Beam=0.25m depth=0.06m draft=0.03m Ratio to actual size boat:1:20 |
| depthofit, personally I'd use a different approach and use the ITTC 57 prodedure to calculate the true scale resistance from model test results. I. Total resistance of scale model is broken down to a resistance coefficient: cT,M = RT,M / (uM² * ρ * SM * 0.5), with cT,M = Total Resistance Coefficient of Model RT,M = Total Resistance Force of Model um = Model Towing Velocity ρ = Water Density SM = Wetted Surface of Model cR,T,m = 3.5 / (1.85² * 1000 * 0.0818 * 0.5) = 0.025 II. Residual Resistance Coefficient of the model is cR,M = cT,M - cF,M with cF,M being the Friction Resistance Coefficient calculated by the ITTC 57 formula: cF,M = 0.075 / (log Rn - 2)² Rn = Reynolds Number = (L * u) / ν with L = LWL and ν = Kinematic Viscosity (1.14E-6 m²/s for fresh water @ 15°C) -> RnM = (0.54 * 1.85) / 1.14E-6 = 8.76E5 Thus cF,M = 0.075 / (log 8.76E5 - 2)² = 0.0048 and cR,M = 0.025 - 0.0048 = 0.0202 accordingly. III. When sailing at equal Froude Number, cR,M = cR,S = cR (Index "S" means the ship in full scale size). Fn = u / √(g * LWL) = 1.85 / √(9.81 * 0.54) = 0.804 This means the full scale ship's speed will be uS = Fn * √(g * LWLS) = 0.804 * √(9.81 * 10.8) = 8.276 m/s The full scale ship's Total Resistance Coefficient can now be calculated as cT,S = cR + cF,S + cA with cA being the Model Correlation Coefficient which - in short - takes several scale effects like skin roughness, towing tank inaccuracies and the like into account. For simplicity I'll use the ITTC standard value of cA = 0.0004 RnS = (LWLS * uS) / ν = (10.8 * 8.276) / 1.19E-6 = 7.51E7 (using ν = 1.19E-6 m²/s for salt water with 3.5% salinity @ said 15°C) cF,S = 0.075 / (log RnS - 2)² = 0.0022 cT,S = 0.0202 + 0.0022 + 0.0004 = 0.0228 IV. Now it's possible to calculate the full scale overall resistance with RT,S = CT,S * uS² * ρ * 0.5 * SS = 8.276² * 0.0228 * 1025.9 * 0.5 * 32.72 = 26209.83N = 26.2 kN However, If I understand correctly you just want to know the friction resistance portions of both model and actual boat (and my drivel above was unnecessary): RF,M = CF,M * uM² * ρ * 0.5 * SM = 1.85² * 0.0048 * 1000 * 0.5 * 0.0818 = 0.672 N RF,S = CF,S * uS² * ρ * 0.5 * SS = 8.276² * 0.0022 * 1025.9 * 0.5 * 32.72 = 2529 N = 25.3 kN Hopefully I didn't mix up my numbers while trying to be a clever Dick... ![]()
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| Eh Olav, fist time I see German in writing. What does it say in English ? All I understand is 'dick' ![]()
| Germaths Well, I used to believe maths and its symbols to be some kind of an "international" language - in addition I now fear my parents fooled me when they claimed my native language they taught me as a child to be German... ![]()
| Wow olav that was really some fabulous math u have there, thanks alot. However, is it really possible to have only 0.672N coming from fricitonal resistance at that speed? With my model being a displacement boat, that speed i mention there is definitely above hullspeed, does that explains for the low frictional resistance? Are the values i provided even credible or logical? 3.5N at 1.85m/s for a 0.54m cat? |
| you need to separate the resistance calculated for laminar and turbulent flow. Do you know where the pins were located and hence the WSA for each? |
| Ad hoc, you are right that there should be some tubulation generators near the bow to assure the laminar flow turning into turbulent at the right position (i.e. where it gets turbulent on the actual boat). However, it seems to me that depthofit did some DIY tank testing without such devices which makes the measured resistance force a little bit uncertain (no offence here, depthofit!). This may also explain the low overall resistance of the model although it's within the realistic ballpark imho and probably the best result one can achieve without access to professional towing tank equipment.
| Thanks. |
| Hi, one thing i don't utnderstand is that for Pe = Rt x V. The Rt is the total resistance at what speed? If Rt is the total resistance at a particular speed, den wad is the V for? Having calculated the total resistance at 8.276m/s, how do i apply the effective power formula? |
| depthofit, "V" in your formula is the boatspeed that "belongs" to the particular resistance force (I called it "u" in my calculation but it's actually the same). Thus your Effective Power at 8.276 m/s is PE = 26.2 kN * 8.276 m/s = 216.83 kW. The other thing you wanted to know is about the scientific notation (interestingly I got a notification by e-mail that you asked this question but that post isn't visible here for some reason... ). For example, 2E6 means 2*10^6 ("2 to the power of 6") = 2,000,000 or 2E-6 means 2*10^(-6) = 0.000002.
| Haha ya, i wanted to ask you about the E but den a fren of mine enlighten me so i quickly change the post into a thnks. Thanks anyway. |
| Who's right Who's wrong? Is A Canoe Stern Better Performing Than A Double Ender? | kudu | Boat Design | 45 | 12-03-2011 05:42 PM |
| Wrong bolts? | BHOFM | Open Discussion: All Things Boats & Boating | 19 | 08-07-2008 11:42 PM |
| Wrong Prop? | Dan Currie | Sterndrives | 1 | 07-16-2007 08:32 PM |
| Whats going on people | Littlebearcanoe | Boat Design | 2 | 09-07-2005 07:06 PM |
| Whats the best yacht ever made?? | Peter H | Boat Design | 21 | 08-22-2005 02:38 PM |
