| MC29: Cat Mono Hybrid... MC29: Cat Mono Hybrid... ![]() Interesting design that needs refining, judging by the amount of spray thrown under way... The lay-out barely meets requirements, even though there is no access into the hulls and the beam is only 8'6"... ![]() http://www.aviadesign.com/MC29/MC29B...let%20size.pdf |
| New thinking in cat design from Glacier Bay founder... New thinking in cat design from Glacier Bay founder... http://www.aspenpowercatamarans.com/pages/Welcome.html ![]() Specs and lay-out: http://www.aspenpowercatamarans.com/...AspenC-80.html I'm not keen on a single diesel, as handling a cat with a single engine mounted in one hull in tight quarters is a serious pain. However, these drawings show an interesting lay-out, including a king size berth, full height head, full size dinette that could convert into a double berth and reasonable size galley all in a compact 26' cat, plus swim platform... Tunnel height, overall beam and lay-out are suitable and it has asymmetric hulls that may bank inside in a fast turn: I can't see why twin outboards could not be substituted to the single diesel engine... Test Boat: 26' engineering proof of concept test hull - no deck, running at 18-24 mph, hands off wheel, burning 2.4 to 3.8 gph with Yanmar 110 hp... Full size photos of Test Boat: http://www.aspenpowercatamarans.com/...photoPage.html However, the hulls configuration is actually that of a proa with a much narrower port hull, which might not lend itself too well to twin outboard power, except perhaps, where a 150HP outboard is used on the main hull and a get home kicker on the other: steering in close quarters would also be much improved... It takes a lot of guts to bring out such radical designs - there are also a 39' and 48 footer - in such dire economic times... |
| I own that Chilkat in Homer. The transom is sound. This boat has been put through the rigors. I trust it and my clients prefer it. It is a comfortable ride in some of the most severe conditions. The Chilkat cruises at 30kts at 4000rpms and consumes 9.5 gallons per hour with Honda 225s. We are seeing more small cats on the Bay every year. Comfort AND efficiency rule the day. |
| Thanks for contributing... Quote:
My only concern however is the low bridge deck, the slope of which is fairly blunt forward, as we operate in open Caribbean waters with no land protection: once it's too rough to get on the plane, then the ride should be rather noisy from the slapping on the bridge deck and probably uncomfortable... |
Seagem, in direct response to the topic which originally started this thread I would say that the best derived design really depends on your stated operational envelope. Then keep the cat as absolutely light as possible. Efficiency is directly relational to weight, and these days it seems that everyone wants to cram as much as possible into a small vessel - that is the chief detractor from performance. |
| No doubt your boat is well built... I have no doubt that your boat is well built and that if any problem had arisen in the first one constructed, it would have been corrected in subsequent editions... Everything I have listed, including 10' beam and high bridge deck, can be done in a small package - that may have to be extended to 28' in length, which is fine by me - and it has already been done by none other than the famed previous owner of Glacier Bay in a 26' boat, which is unfortunately a single diesel PROA!!!... http://www.aspenpowercatamarans.com/...AspenC-80.html Don't forget to take the 360 degree tour of the accommodation mock up... Quote:
| Cat hulls http://www.ecocats.com/8mChaseboat/t...1/Default.aspx These guys have it close to what would work in the Florida Keys. A 22 to 24 x 8 to 9 beam and shallow draft hulls of 8 inches or less, a fat cutwater, and ballanced level no matter what engines you stick on her. Light weight and stable. T Top or full overhead B |
| New Catamarans launched at Seaworks 2009 show We have just lauched a range of catamarans that are very efficient and sea kindly further details at our web site fullbarcomposite.com We are currently developing a 9.9m model for the UK fishing industry. I will post further details this evening Cheers Simon |
| Need fast, EFFICIENT, commuter boat | MattM | Boat Design | 47 | 05-19-2009 09:39 AM |
| Fast racer cruiser 11m hull & deck moulds | downsouth | Boat Molds | 1 | 09-30-2008 02:31 PM |
| Formula catamaran hull shape | steve.b | Multihulls | 7 | 08-20-2008 05:50 AM |
| Most efficient hull shape? | runiuc | Boat Design | 5 | 08-08-2008 10:46 PM |
| Transom vs. V Shape for Catamaran Stern Hull | Free Pirate | Boat Design | 15 | 03-17-2005 07:16 AM |
