Old 06-18-2002, 10:49 PM
dolphin300 dolphin300 is offline
Rep: 10 Posts: 16
What is the most environmentally friendly propulsion system?
Which is better: a 4-stroke outboard or a diesel inboard?
Is an above the water air-exhaust better than an underwater exhaust, if not for the passengers for the environment? Are converters available to clean up the exhaust?
What about electric? With the double conversion and the extra weight, more overall energy is used plus the dangerous materials used to make the batteries - is the powerplant generating the electricity much cleaner than a small marine engine can be made to be?
Old 06-18-2002, 10:54 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Re: What is the most environmentally friendly propulsion system?
Sail.
Tom Speer
Old 06-18-2002, 11:49 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
how about an oar?. Biodegradeable of course
Old 06-19-2002, 12:19 AM
Portager's Avatar
Portager Portager is offline
Rep: 322 Posts: 418
Environmentally Friendly
"Which is better: a 4-stroke outboard or a diesel inboard?"
The diesel inboard because it will burn 1/3 to 1/2 as much fuel to produce the same amount of power.
"Is an above the water air-exhaust better than an underwater exhaust, if not for the passengers for the environment? Are converters available to clean up the exhaust?"
The amount of pollutants produced is independent of the type of exhaust. If properly designed both are equally acceptable for the occupants. The EPA is instituting new environmental requirements for diesels and outboards starting with large engines and working their way down. These regulations have already produced significant improvements. The best you can do for the environment is to get a new electronically controlled engine and maintain it properly.
"What about electric? With the double conversion and the extra weight, more overall energy is used plus the dangerous materials used to make the batteries - is the power plant generating the electricity much cleaner than a small marine engine can be made to be?"
If the electricity is generated by natural gas or nuclear it is better. If it is produces by coal it is worse. The power plant fuel conversion efficiency is typically 40%. The electricity generation and usage efficiencies are about 90% each. Battery charge conversion efficiency is 85% for flooded lead acid batteries, 90% for Gel cells and 95% for absorbent glass mat (AGM) batteries. The net energy conversion efficiency is 28%, 29% and 31% respectively. For diesel engines the fuel conversion efficiency is about 34%.
Cheers;
Mike Schooley
Designing "Portager" a transportable passagemaker
Old 06-19-2002, 12:37 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
What about fuel cell to electric. With a hydrogen fuel cell the waste is heat, water and oxygen.
Gary
Old 06-19-2002, 01:51 AM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Yoy guys are all forgetting Trouty's Neutron Drive!
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 06-19-2002, 01:56 AM
Re: Environmentally Friendly
This ignores the difference in weight between the two powerplants. Our 225hp Optimax's can return over 6 nmpg at around 6-7 knots - and that's on a heavy, deep v runabout - hardly the most efficient displacement hull shape. I'm sure that a small diesel could probably better this - but it wouldn't push the boat to 60 knots!
So, I think it really depends on what the application is.
Will
www.imaginocean.net
Old 06-19-2002, 03:49 PM
Portager's Avatar
Rep: 322 Posts: 418
Fuel Cells
Currently available fuel cells run on pure hydrogen. This is fine is you plan to tow the Hindenburg behind your boat, but I hope you don't intend to go up wind or smoke.
To run a fuel cell on higher density fuel you need a reformer. Today, most reformers use natural gas (still not dense enough to fit much fuel in the tank). They are still working on reformers for gas and diesel. In addition to hydrogen gas, reformers produce CO2, CO, NOx and waste heat.
Cheers;
Mike Schooley
Old 06-22-2002, 06:39 AM
lockhughes's Avatar
lockhughes lockhughes is offline
ElectricGuy
Rep: 27 Posts: 110
Location: Wards Island Toronto north shore, Lake Ontario
Compromise? Have read some articles about powering an permanent magnet brushless electric motor with a smaller gas or diesel generator. Motor can have maybe one moving part (direct drive to the prop) and can be 80% efficient or more. Genny avoids water cooling, etc and are typically far more efficient (than gas/diesel engines) also...
Lock
Old 06-22-2002, 11:09 AM
Portager's Avatar
Rep: 322 Posts: 418
What drives the Genny
What drives the generator? Don't you still need a gas or diesel engine to power the generator? If so then you are starting with the efficiency of the gas or diesel engine and then reducing it by the efficiency of the generator and then reducing that by the efficiency of the motor.
It is like pumping water through a leaky pipe. If you loose a percentage of the water along the way you can't get out more than you put in. In fact you will always get out less than you put in. The way to minimize the leakage is to shorted the pipe. In the case of the drive system the way to minimize the power losses is to eliminate the inefficiencies. This usually means connecting the power source directly to the prop.
The reason there is no enforcement of the laws of physics is because nobody has figured out how to break them yet.
Cheers;
Mike Schooley
Old 06-23-2002, 01:12 PM
Yup... Dolphin300 didn't specify max.speeds or operating distances, etc. So I was *guessing* he'd want something with more range than just batteries?
You're right. It's just that, as I understand it so far, the newest permanent magnet electric motors are hitting efficiencies something like 80-90% or better. And the gennys are also more efficient than electric or diesel engines - a lot. So combine the two, and you're still well ahead of the straight water-cooled
"traditional" gas/diesel engine?
Agree totally Mike. One obvious power loss is vibration and noise - the newer gennys can be whisper-quiet. Electric motors also. So obviously they're more efficient in this regard alone?
Here's an article (sorry, PDF-format) that highlights the inefficiencies of the diesel engine:
http://www.solomontechnologies.com/p...ic%20Wheel.pdf
Turns out they're *so* bad, it's not hard to come up with something better! There are a lot of criteria that might determine what propulsion system is best, but the original post
specified "Environmentally Friendly" as the acid-test. I think Tom had it right with SAIL <grin>... But that doesn't seem to be an option for Dolphin300. (My little boat is sail-only and regularly hits 15-20+kts, but Dolphin may not wish to get so wet?
The reason there is no enforcement of the laws of physics is because nobody has figured out how to break them yet. Cheers;
Mike Schooley
Hehe... true, true. I'm liking the electric approach more and more though, as fuel cell, capacitor and battery technology, and wind and solar generators appear to improve and become more viable over time. I don't see the gas/diesel approach improving much more in the future. The genny suggestion was sort of a short-term solution?
I read your earlier post about the efficiencies of electric power-generating stations, which I'm sure has to be factored into the equation. I'd be *hoping* to recharge on wind and solar as much as possible. Electricity from shoreside fuel cells (electricity from gases) as well, at some point in the future.
Lock
http://groups.yahoo.com/group/QCYCTender/
Old 06-24-2002, 01:00 AM
Portager's Avatar
Rep: 322 Posts: 418
The Electric Wheel
Lock;
I read "The Electric Wheel" article by David E. Tether with amusement and disbelief. David has a valid point regarding the torque versus speed curve. Some electric motors have a flat torque versus speed curve which makes them very effective at starting up heavy loads. This is why we have diesel-electric locomotives and tug and it explains why his sailboat conversion to electric was successful.
As David pointed out the main advantage of an electric sailboat is the ability to use the prop and electric motor as a generator to recharge the batteries.
The discussion regarding parasitic losses is less technically founded. While it is true that noise is a type of wasted energy, the energy density of noise isn't very high. If it were, I could solve the worlds energy problems by connecting a microphone to my kids. The other parasitic losses that he mentioned, such as oil and coolant pumps, are already taken into account in the engine power rating. By deducting them again he is double booking and inflating them to boot.
On a diesel-electric system the generator and electric motor take the place of the transmission. Boat transmissions typically have a power transmission efficiency of 98%. David claims that the efficiency of their motor is 94%. If the generator is also 94%, then the net transmission efficiency is 0.94 X 0.94 = 88.36%. In my book 98% beats 88.36%.
David's discussion on generators is well I'm trying to be nice, so ... Apparently David is talking about AC generators since he states that they run at constant speed. The problem with AC generators is they must run at constant speed to produce AC power at the right frequency (i.e. 60 Hz or 50 Hz). The thing about engines is they provide their best efficiency when speed is allowed to vary with the load. Running an engine at high speed and low load is very inefficient and hard on the engine. An AC generator is the wrong choice for a diesel-electric boat because you would then need to convert the power from AC to DC which requires an inverter. Inverters are typically about 85% efficient. A much better choice is a DC generator. DC generators are more efficient that AC and they can run the permanent magnet electric motor and recharge the batteries directly. In addition, a DC generator can adjust its speed with the DC load and operate more efficiently and at low loads it is much quieter.
Cheers;
Mike Schooley
Old 06-24-2002, 04:13 AM
trouty
Neutron drive?
Neutron Drive...sheesh - can't you guys git anything right?
I'll say it agin fer ya's so listen up n pay attention coz theres a test on this at the end OK?
Now this systems not to be confused with the Fractored Amplitude Reactive Thermistor (FART) drive....OK?
Far from just sounding the part - my system has the guts to leave skid marks in your undies for real..
See if you can get this down in one go...
Powered Obtuse Overunity Plasmoidal Induction Scalar Electromagnetic Hydrodynamic Caterpillar Drive. (Poop for short )
Heres a little schematic and notes to help you all get the hang of this.
Internal wave structure of the scalar potential
Internal wave structure of the scalar potential (end)
The overunity principle, the secret of extracting and using free energy!
Too simple really - just hook up the scalar electromagnetic collection overunity device to my hydrodynamic, plasmoidal induction drive system, and jacks your aunty, (at least she would be if she had balls) - free energy drive system.
Yup yup yup - this is the most environmentally friendly propulsion system known to man or beast...
Just one problem tho...
The men in black!
Sneakin it past them takes a whole lotta doing...Let me tell you guys that the Bush oil cabal running this world today aren't too pleased at all about scalar electromagnetics...heck - they arent even one pleased!
Luckily - I have Jake and Elwood workin on that as I type!
Lifes pretty straight without a twistee eh?
Cheers!
Old 06-24-2002, 09:38 AM
lockhughes's Avatar
ElectricGuy
Rep: 27 Posts: 110
Re: The Electric Wheel
Lock;
oh boy... ok Mike, burst my bubble <grin>
*some* have flat curves, not all? Don't know what the variations are, but it yeah, I gathered that is a plus for marine propulsion - at least, the kind involving heavy, displacement craft.
Yup. got that. I'm interested in a electric-only craft myself. Somehow your post on the EWheel ended up in this thread (most environmentally friendly), and I'm guessing Dolphin isn't looking at the sail option either <sigh>
hehe... Makes sense. Though I must say, our old club tender (diesel) shakes and shudders. Noisy, yeah, but the vibrations are *huge*, now that folks like David T. make me think about this stuff. I'm sure the new (diesel) craft our Club is getting will be a whole lot better behaved, but if I look in the engine compartment and see really big motor mounts/vibration dampeners... well, that'll tell me something right there!
Darn. Should try and get David T. aboard here - give him a chance to refute (elaborate? obfuscate?<wink>)
wait a sec Mike. Shouldn't you be factoring in the efficiencies of the deisel engine into the 98% side of the equation? All that stuff about driving alternators and water pumps, whatever?
-SNIP-
OK, now I'm going to go away and try and read up a bit on generators. Not my primary interest (sail) or relevant to my little project on a club tender (plugged into shorepower/solar/wind),
but might end up being a factor for the tender anyway... thanks
Lock
Old 06-24-2002, 02:23 PM
Portager's Avatar
Rep: 322 Posts: 418
Re: Re: The Electric Wheel
Sorry to burst your bubble, but reality can be soooo confining. Where is that portal to the alternate dimension where everything works the way I want it to. O yea, its called dreaming.
Suffice to say that the permanent magnet motors that Solomon Technologies is using have a flat torque speed curve over the range of speeds they are using.
The question I was responding to wasn't specific to electric only propulsion. Electric only is OK for short range applications. My earlier post comparing the efficiency of a diesel versus electric using shore power would apply. Due to the inefficiencies involved the diesel is actually slightly higher efficiency that the electric unless you have access to a clean source of power such as hydro-electric, ... The other advantage of the electric option is noise and maintenance (until you have to replace the batteries).
Modern "light weight" diesels have a problem with vibration. To lighten the engine the manufacturers have lightened the flywheel and greatly reduced the angular moment of inertia. Since 4 cycle engines (most diesels are 4 cycle now days) only fire every other revolution, they have power pulses every 720 degrees/number of cylinders, for example a single cylinder gets a power pulse every other revolution, a 2 cylinder gets a pulse once per revolution, a 4 cylinder gets a pulse every 180 degrees, ... Since each power pulse is essentially a half sine wave, the 4 cylinder will have almost a continuous sine wave power curve going from 0 to max and back to zero every 180 degrees. In a 6 cylinder the power pulses start to overlap and in an 8 cylinder they almost level out. To get a smooth running diesel you want as many cylinders as possible. If that isn't possible, then a high inertia flywheel id the next best thing. So, if your new boat runs too rough get a higher inertia flywheel.
wait a sec Mike. Shouldn't you be factoring in the efficiencies of the diesel engine into the 98% side of the equation? All that stuff about driving alternators and water pumps, whatever?
If we are comparing diesel-electric drive to diesel-mechanical drive then both systems have the same diesel engine driving them and that cancels out. The generator and motor are just an alternative to a transmission.
If you want to compare a diesel-mechanical drive to an battery driven electric drive using shore power then it is a slightly different matter. The shore power generator is slightly higher efficiency (~40%), you have to factor in transmission losses (depends on the distance to the power plant optimistically 0.99 ), battery charger efficiency (multiple by 0.85), battery charge efficiency (multiply by 0.95) and then electric motor efficiency (multiply by 0.94) Net result is 30%. The diesel engine is slightly lower efficiency (~34% which includes the parasitic losses for the coolant and oil pumps) and then you must deduct parasitic losses for the alternator (varies from 0.95 right after start-up to 0.98 once the batteries are charged), transmission losses (multiply by 0.98). Net result is 31.6% to 32.6%.
If I broke your bubble I am sorry, but reality made me do it!
Cheers;
Mike Schooley
New propulsion System tom kane Open Discussion: All Things Boats & Boating 35 06-09-2005 12:06 AM
Another new propulsion system DEDave Boatbuilding 12 09-09-2004 10:25 PM
Low Drag Propulsion System Thunderhead19 Boat Design 5 05-25-2004 10:41 AM
Propulsion system drag CAS Powerboats 5 11-19-2003 12:32 AM
New jet propulsion system Guest Boat Design 10 10-30-2003 03:28 PM
