| Narrow double enders have hulls speeds of up to 3xsquare root of wl.
__________________ Gonzo |
Sailing dinghies that are sufficiently light-weight will usually plane even in light to moderate winds. Nonetheless, for a large portion of it's sailing life they perform as displacement craft which they are.
| Grumman Canoes had 2 hull styles. Flat bottom for sport speed use, and a rounder bottom for camping or as they called it back then- "freighter use"- 16' and 18' rated for 2,000 to 3,000 pounds of cargo. They were very deep and wide hulls that were used as " freighters ". All had a stern out board bracket because the average side breeze would kill the best paddelers in a short time. |
| Gonzo, how narrow is "narrow" in that context? Putting my w/l beam at 3 ft, and the w/l length at 16 ft, that gives a w/l ratio of better than 5 to 1 length to beam. Any way to guess at where the critical speed might lie in a hull of this shape and proportions, where "planing" however defined, starts (given as the multiple of the sq rt of w/l, not knots)? Tony. |
| All planing hulls can move at displacement speeds. If they are designed for planing they will perform efficiently at high speed. Tonyr: I think that hull fineness is a better reference because a very narrow but deep hull will have a low maximum speed. Also the shape has a lot to do. Easy sweeping lines with the beam about 55-60% aft seem to get higher speeds. Straight buttocks help streamline the waterflow and create less turbulence.
| Tony An international moth is a planing boat and is relatively narrow . I think over 10:1 For a simple rule of thumb to predict planing speed use velocity = k * LCG / SQRT (B) k = Constant 4 for ft 7.2 for metres LCG = Distance from logitudinal C of G to transom B = Beam see the following. see http://www.hydrocompinc.com/knowledg...aningSpeed.pdf another interesting online reference is http://www.mothboat.com/USMMCA/Building/hull.htm All the best Gareth |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 02:20 AM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| Building my first boat. | ihallenius | Boat Design | 18 | 08-03-2005 02:02 AM |
| Boat Design Proj | designfreak | Boat Design | 31 | 04-15-2005 03:20 AM |
| Naval Architect Book? | Bill_Smith | Boat Design | 16 | 11-17-2004 11:08 AM |
