| What kind of Core material should i use? Hello. The plywood core in my Tanzer 16 rotted out. I've removed it all and now need to recore the deck. Can anyone suggest a good coring material for a small job? Thanks |
| Have you still a laminate on the deck (underside)? If that's the case it's propably quite "soft" and leaves only a couple of possibilities. Either vacuum bagging a new core, or hand laying it in smaller pieces. Quote from the rules: "d.Plywood hull and deck core material may be replaced with other materials, such as balsa or Airex foam, at the discretion of the owner." Corecell is good too.. http://www.tanzer16.org/Specifications.aspx |
| We removed the top layer and all of the playwood, then ground down to bare fiberglass. I was figuring we could lay sheets of coring. The Corecell you mentioned looks like it would work OK. |
| Just remember to put some hardwood or smth in the fastening places... makes things a lot easier later.. |
| I'm not clear what you mean about the hardwood pieces. Would i not just glue down the core, then glass over it? |
| Use marine ply, encapsulate it with epoxy resin and call it a day. It will last longer than the rest of the boat. And you must not redesign anything, just go for the old sizes. Regards Richard |
| If you have any intend to fasten anything else but stickers put those places something solid instead of foam.. ps. Richard is right.. it's not so big piece of ply.. |
| Plywood will cost 5 to 10 times less then the other coring choices you have. |
| Thanks for all the great input everyone. I think plywood wins. |
| What kind of material for mast for a Steel Cruiser ? | Coach Mac | Boat Design | 14 | 11-01-2010 02:43 PM |
| New 'foam' core material? | Stumble | Boat Design | 33 | 05-31-2010 08:11 AM |
| which core material ? | aldo | Boat Design | 8 | 10-26-2005 07:37 PM |
| Transom Core Material | Aaron23 | Fiberglass and Composite Boat Building | 4 | 01-07-2005 10:10 AM |
| Polyurethane as Core Material | Victor Lemmi | Materials | 3 | 07-03-2004 01:39 AM |
