Old 10-29-2007, 02:59 PM
justinDesign justinDesign is offline
Rep: 10 Posts: 29
What hull should I use?
I am currently designing a bass boat and desire a hull with very little draft and a fair amount of stability. The vessel will be in the 12ft by 6 ft range used primarily for river fishing. These are the hull types I have been contemplating inverse vee, catamaran, tunnel hull, and tunnel vee. If anyone could rank these for me, tell me the pro’s and con’s, or supply another option, I would appreciate the help. If this helps any I intend to use a surface drive outboard to power the vessel.
Thank You
Old 10-29-2007, 03:36 PM
RatliffFranklin RatliffFranklin is offline
Rep: 15 Posts: 191
Hulls
Thank You
An airboat hull?
CLP; mono-hull vs multi-hull jibbernaught Boat Design 0 06-05-2007 03:07 PM
differences between nitro hull and vee pad hull riveramunizaga Boat Design 4 05-24-2005 10:27 PM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 02:18 PM
hull boat redesigns (hull pad project) riveramunizaga Boat Design 9 05-12-2005 08:35 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 12:27 AM
