Old 11-30-2011, 06:04 AM
kraaiboskloof kraaiboskloof is offline
Rep: 10 Posts: 3
What have I just bought?
Old 11-30-2011, 06:24 AM
Rep: 10 Posts: 3
yes apparenly homebuilt from a design by robert tucker
Old 11-30-2011, 08:52 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Probably used on Knysna lagoon...?
Suggest that you give her a once over with shot blasting to see how well she is preserved under the paint and apply new primer. Do the necessary repairs and repaint and you should have a boat to use
Wynand
A scatterling of Africa
Old 11-30-2011, 02:00 PM
Rep: 10 Posts: 3
Thanks for advice what is "shot blast"?
Old 11-30-2011, 02:14 PM
drunkin clown's Avatar
drunkin clown drunkin clown is offline
Rep: 10 Posts: 14
Why didnt you just ask if you could have it?You spent hard earned cash on that?What does your wife think?Shot blast means to sand blast the hull I think...then again it could mean, Have a shot and blow it up!
Old 12-01-2011, 12:25 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1474 Posts: 1,620
kraaiboskloof if you got a bargain it could be ok
but beware - an old hull can cost serious bucks to fix
it could be so bad that building from new will cost the same
What Wynand said is true, clean up first
a wire brush wont do the trick
it has to be sandblasted in and out
your local engineering works should have one, just rent a very big compressor and make sure the operator wears all the safety gear
good luck - you are going to need lots of it
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
K-19 just bought plans gotthebug Wooden Boat Building and Restoration 66 03-02-2012 07:53 AM
so I bought this boat.......... nate teach Sailboats 21 05-31-2011 02:58 PM
Just bought a project tri taezow Multihulls 13 07-25-2010 02:56 PM
I bought a motorhome gonzo Open Discussion: All Things Boats & Boating 39 11-29-2009 04:36 PM
just bought a fixer upper and need some help... petrey10 Boat Design 0 06-24-2007 08:48 PM
