Old 04-13-2005, 12:21 PM
abrahamg abrahamg is offline
Rep: 10 Posts: 2
What happens if I increase the size of the boat by 30% than the intented size
Hi everyone
Can anyone tell me what happens if i increase the size of the sailboat by 30% for construction than it is intented for as stated in the design ???
( Basicly I intent to add 30% to all dimentions, including the frame thickness)
Also please tell me how make a wooden mast or to find out the radius for a given mast and to put the sail groove in a wooden mast
Any input will be greatly appriciated
Abraham
Old 04-13-2005, 03:28 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
I believe that this is a very bad idea, because the resultant effects on stability, resistance and the resulting forces on mast steps and decks doesn't change in simple proportion. You could be horrified at the outcome unless you crunch the numbers.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 04-13-2005, 04:39 PM
jfblouin's Avatar
jfblouin jfblouin is offline
Rep: 24 Posts: 163
When you change lenght by 30%, you change area by 69% and volume by 120% so your old boat of 30 feet and 6000 pounds displacement look 39 feet long and 13200 pounds displacement after a 30% upgrade. Like Thunderhaed16 said, all parameters while be change, you need to redesign the boat.
Old 04-23-2005, 11:42 AM
Rep: 10 Posts: 2
Thanks buddies.... I was just about to do that.. I changed the berths and the galley and the stowage and was thinking that's it, I got a bigger boat with more volume and cruising capacity.... Guess I have to start all over again....
Old 04-23-2005, 01:10 PM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
Yeah, I guess you do.
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Old 04-24-2005, 06:47 AM
Rep: 700 Posts: 3,207
Most times it works just fine , IF you crunch the numbers properly.
It will take loads more than a 30% increase in balast , and sail area.
You Might get away with only a 30% larger engine , as many sail boats are way overpowered to start with.
FAST FRED
Old 04-26-2005, 07:09 PM
chandler chandler is offline
Rep: 16 Posts: 378
Francis Kinney has a law of similitude. It deals with changing dimensions in designs. Maybe take a look at it in Skenes elements of yacht design. An excellent book anyway.
He worked for Sparkman and Stephens as well as Rhodes so I think he may know what he's writing about.
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Has anyone here started a boat building business from scratch? aqualoco Fiberglass and Composite Boat Building 61 09-27-2005 01:18 PM
Restoring an old boat, starting with the floor. jsass Boatbuilding 7 06-24-2004 09:56 PM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
