Old 07-07-2006, 12:14 PM
willfishforbeer willfishforbeer is offline
Rep: 10 Posts: 15
What is the formula for Max. HP on a flatbottomed boat?
I've heard there is a different formula than the 2xLxW-90 for boats with flat bottoms, is this true? Or is it safe to use this one?
Old 07-07-2006, 12:47 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Go and use a Savitsky power prediction. Enter all your boat details and calculate the power you will need for your desired speed.
There is a spreadsheet available on this forum.
Personally, I don't usually like rough equations. The only one I take any heed of is the one for "Hull-speed" but only then as a rough guide.
Good Luck,
Tim B.
Old 07-07-2006, 05:03 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
If the boat is under 20 feet in length then the Coast Guard formula is, 1/2 the length times the maximum transom width - 15. See http://www.uscgboating.org/safety/bo...g33_183_4a.htm
If it's 20 feet or over you can put what you want on it. I would do a manuevering test or use Saitsky. Personally I prefer the manuevering test.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 07-08-2006, 09:42 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
The CG says it a bit different but it works out the same. The CG says it is the factor that is multiplied by .5 and the factor is Length times the max transom width (including rails etc) eg (16 * 4 = 64) so 64 * .5 = 32 -15 =17 (same as what Ike says, just so the different wording doesn't confuse anyone) ...rounded to the next highest 5. So this boat has a max hp of 20....according to the USCG...Provided it isn't remotely steered or has a transom of over 20 inches...then its ????????. They have a bunch of problems with these formulii. Use common sense and slow down in turns with a flat bottomed boat so you don't trip on the chine and you should be fine.
BTW, for the same boat and your formula it works out to 38 hp...a bit excessive for a 16 x 4 ft flat bottom.
Steve
Plans for a Formula 2000 boat Femte Powerboats 0 07-06-2006 07:00 AM
3D Max tug Bassoom Software 2 06-11-2005 08:38 AM
Sail Boat Formula pmusu Sailboats 4 06-04-2005 04:47 PM
Max Area Formula? Wynand N Boat Design 2 03-07-2005 04:56 PM
max RPM for a sail boat jihed Boat Design 4 08-02-2004 02:43 PM
