Old 04-11-2005, 07:09 PM
Yolinda K. Yolinda K. is offline
What exactly is square foot
Im trying to figure out the square footage of a boat hull. What is the method one uses to calculate this by hand??
Formula, steps. all would be appreciated
Yolinda
Old 04-11-2005, 08:24 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Are you trying to calculate the hull surface SF. Or maximum SF of the boat when viewed from the stern. Or some other surface? Or a combination of surfaces? Due to some very curvy areas it is a very difficult task that is dependant on hull shape. Hand calculation is a approximate answer at best.
Old 04-11-2005, 08:33 PM
Short of cutting pieces of paper and taping them on the hull I have no idea of the accuracy by the non-use of some exotic cad cam tracer program.
Old 04-11-2005, 08:38 PM
I gave my old slide rule away years ago. That was a real hand job calculator. I have a few hulls that could keep some one busy.
Old 04-11-2005, 11:23 PM
Rep: 1623 Posts: 1,483
Google "Simpson's rules", About half a hundred ways to get exactly what you want. If you really want to get cool use one of Tchebycheff's rules.
Old 04-13-2005, 12:14 AM
PAR PAR is online now
Rep: 2891 Posts: 8,792
Trapezoidal method or Simpson's if intrested in pain. Plainmeter or software if not.
Old 04-13-2005, 02:23 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
This forum has an informative thread. Just search this forum for
"wetted surface area - approximate formula"
If you don't change tack, you will end up where you are heading.
Square Rig pointing - questions percyff Sailboats 22 11-25-2009 04:29 PM
12 foot sheet marine ply suppliers in UK alyne Materials 2 09-09-2005 01:57 PM
open 20 footer usa2 Sailboats 116 03-22-2005 01:33 AM
Refinishing/coating costs of boat per square foot alexhiguera Materials 0 02-04-2005 08:11 PM
Restoring 32 and 36 foot ChrisCraft plywood plank boats boatnut007 Wooden Boat Building and Restoration 7 08-29-2004 09:37 PM
