Old 04-04-2004, 10:15 PM
snapper340 snapper340 is offline
Rep: 10 Posts: 23
What do you think?
Hey guys, I have a design that I need advice on. I need to know first, will this boat plane, if not, what changes do I need to make? Second, what kind of horsepower do I need to get the boat to 40 knots safely? Third can I go this speed and still be stable? I am building this boat out of plywood, using the stich and glue method of construction. The bottom will be 1/2" plywood, and the 1st and 2nd chine will be 3/8" plywood. I don't know what the boat will weigh yet, but I am hoping to run in less than 12" of water with it. I want to make the deck plan like a bass boat, But that is subject to change depending on what needs to be changed to get what I want as far as speed, stability, and safety.
Thanks for the input.
snapper 340
Old 04-04-2004, 10:30 PM
Rep: 10 Posts: 23
sorry, my attachment didn't go through, it appears that I cant upload a Carene 50 file, Is there a way I can post the attachment on the forum?
snapper 340
Old 04-04-2004, 11:07 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Sorry, what is the file extension?
Old 04-05-2004, 11:40 AM
Rep: 10 Posts: 23
It's a d.50 file
snapper 340
Old 04-05-2004, 01:01 PM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
Carena 50 file...
But how would we view it?
If itäs a pi just upload a jpg or whatnot
Old 04-05-2004, 04:29 PM
Jeff's Avatar
Moderator
Good point Erik,
I went ahead and added .d50 and .50 as valid file extensions, but as Erik says, you will almost certainly get a far greater amount of feedback if you post some jpg's of the lines.
Old 04-09-2004, 09:10 AM
Zed
Dynamic Stability and Resistance
Sorry,
you don't even provide the most bastic dimensions which would allow a guesstimate. I spend most of my day doing resistance, powering and stability and my comclusion can only be that this is way exceeding what you could expect from a internet messageboard.
Sorry
Zed
Old 04-11-2004, 06:22 AM
ars-technica's Avatar
ars-technica ars-technica is offline
Naval Architect
Rep: 16 Posts: 192
horsepower
To determine horsepower use savitsky
