| What do these strakes do?
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| Are these also strakes? Or are neither set strakes? http://www.militaryphotos.net/forums...-Country/page4 ![]() http://www.portierramaryaire.com/for...&sd=a&start=30 ![]() http://www.duramax-international.com/Recent.asp ![]()
| And what the heck are these? http://www.duramax-international.com/Recent.asp ![]() ![]() ![]() ![]() ![]() Some sort of thruster? Which part of the waterjet is this? http://www.duramax-international.com/Recent.asp ![]()
| Last ones look like heat exchangers, but no idea on the strakes... |
| Those strakes are probably there to protect the hull in areas susceptible to damage from bumping into jetties or tied along other vessels. You find similar on trawlers, in the area where the fishing gear comes in. Also on a diversity of work boats, like service vessels, tugs et c. . The hull openings are for what we call grid coolers. Judging from size (hard to tell though since no referrence objects) it might be for airconditioning or stand-by gensets. |
| Duramax makes heat exchangers, which is what is behind the grids in the sides of the vessel. The waterjet appears to be a Schottel pump jet (SPJ). The picture is of the foundation for the thruster. http://es.wikipedia.org/wiki/Patrullero_Fluvial_PAF_III http://www.schottel.de/eng/r_produkt...uebersicht.htm Douglas |
![]() At the risk of straying my own thread off-topic, why don't we see such pump/fan configurations on air breathers such as aircraft and hovercraft? Doesn't air act as a fluid in most situations? As in computational fluid dynamics?
| spray defectors that are also somehow low radar signature? maybe they some crap they could could only get in that shape or fasten at certain points, thus not optimized water-wise. |
Maybe a super low profile blimp designed for storm sewer inspection or spelunking could make effective use out of this type of propulsor--that would be the kind of highly-specialized requirement needed to force adaption of this type of propulsor (and even that is questionable). ![]() This type of thruster is usually only preferred on marine vessels where (1) azimuthing thrust is desired/required and (2) draft is limited. A side benefit is the compact installation footprint compared to a retractable thruster or inline jet thruster. Where draft is not limited, a drop-down and non-retractable azimuthing thrusters will provide higher thrust for the same engine/motor input power. Where draft is limited, but azimuthing thrust is not needed, a tunnel thruster offers a simpler (less expensive) alternative. Douglas |
It's always the efficiency thing, which is ironic because once you lift the hull up and operate in a medium 1/100th as dense as water (air) you can get pretty efficient. ![]()
| concur in both cases. The well IS for housing a SPJ installation (youŽll find another one on the other side of the vessel). And the "strakes" are just reinforcements of the hull in high load areas. All Rig supply vessels (AHTS) and modern tugs sport similar structures. They could be executed on the inside of the hull, but that would interfere with the frames and stringers. Regards Richard |
Correct? I'm guessing this is one of the larger craft on the river and may indeed push drug running boats aside after capture or capsize them without use of firearms. EDIT: Buque Nodriza translates into "Parent Ship". Nodriza translates to; Nurse Ship hull up against river bank/shore......................notice access door. http://www.fotosmilitares.org/viewto...st=0&sk=t&sd=a ![]() Inside: same link as above http://www.fotosmilitares.org/viewto...st=0&sk=t&sd=a ![]() I'm guessing that the diagonal ones work better than the horizontal ones considering tide height rises and different heights of ships being boarded. http://www.fotosmilitares.org/viewto...1137&start=300 ![]()
| Nothing new under the sun..........looks to be WWII era. http://funkoffizier.wordpress.com/ca...allas-navales/
| I didn't know that river patrol boats need to be of low radar signature type. Thought that mountains, hills and trees are enough to hide them during operations. |
| Help for strakes | jfblouin | Boat Design | 3 | 12-03-2005 11:19 AM |
| strakes | ARGO | Powerboats | 19 | 07-21-2005 06:34 PM |
| Strakes | ARGO | Boat Design | 1 | 05-15-2005 05:08 PM |
| strakes in maxsurf | fede | Software | 1 | 04-13-2004 08:09 AM |
| strakes | Guest | Boat Design | 1 | 11-08-2003 11:41 AM |
