| Wellcraft Diesel Conversion Hello and sorry if this is in the wrong forum, I can't really seem to find any technical boat forums to ask my question. I have acquired a 1985 26' Wellcraft Aft Cabin, which currently has a mercruiser 350 in it. I have 2 Cummins 4bt (4 cyl, 3.9L) diesels lying around, and I'm hoping I can convert one of them in the Mercs place. We will be fueling the engine to 250hp @ 2500 RPMs. I just have a couple questions. 1. My sterndrive is a Merc Bravo I (IIRC) with a 1.47:1 ratio, given the diesel wont be turning the rpms that the V8 does, I'm thinking this will turn the boat into a slug. Does anyone know what alternatives there are to this? Optimum would obviously be more of an overdrive ratio of .5-.8:1 to keep the prop speed up. 2. The Merc engine weight as I seen through specs online, is 1200lbs, the 4bt fully oiled up etc. is 800lbs. So there should be no concerns with the hull holding up? |
| 4bt I am not sure of options for spinning prop faster with that drive other than using a larger prop or diff pitch for some more push. I would be interested if you are selling the extra 4bt. I would be putting it into a direct drive and i know the options to gear up or down are good in that aplication. |
| Twin V6 to single diesel conversion | burt2 | Propulsion | 21 | 02-01-2011 07:00 PM |
| Diesel to electric conversion | kach22i | Propulsion | 3 | 09-06-2007 07:47 AM |
| planing gas to displacement diesel conversion | jeemboNC | Diesel Engines | 14 | 01-20-2007 05:11 AM |
| Twin inboard gas to single diesel conversion | goodidea28 | Diesel Engines | 1 | 09-06-2006 11:48 PM |
| anyone with a Wellcraft out there.....? | btravlin | Powerboats | 2 | 10-16-2004 11:28 PM |
