Old 10-25-2007, 03:57 PM
tevhit tevhit is offline
Rep: 10 Posts: 5
Welding Astm316 Stainless Steel
I Need Advises About Critical And Important Points In Welding Stainless Steel Astm 316.
Thanks In Advance
Old 10-25-2007, 07:46 PM
Previous Member
Rep: 0 Posts: 0
MIG TIG STICK?
Just check your polarity if stick welding, you will get on better with higher open circuit voltage machine, but most machines ok, , use 316l rods or wire
What are you doing?
you can PM me if you like, I am interested in Tr
Old 11-02-2007, 02:17 AM
Matt.D Matt.D is offline
Rep: -9 Posts: 78
Tig is the best way to go, much cleaner finish but just make sure u brush cleaning acid on the welds then after about 5min wash of fwith water or ur s/s will eat it self away! Matt
Steel Welding query JimCooper Metal Boat Building 23 08-13-2009 03:46 AM
Welding stainless steel hazards SamSam Metal Boat Building 0 11-28-2006 07:10 PM
Stainless steel and polyester GeoffSChapman Materials 2 11-14-2006 12:19 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 07:40 PM
welding steel plate on a keel lockd Metal Boat Building 4 11-10-2005 06:50 AM
