Old 04-19-2008, 07:59 PM
timwithoutaboat timwithoutaboat is offline
Rep: 10 Posts: 4
The weight of a keel
can anyone tell me how to work out how heavy a keel should be?
Old 04-19-2008, 08:35 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
For what?
Old 04-20-2008, 03:41 AM
Nordic Cat's Avatar
Nordic Cat Nordic Cat is offline
Rep: 72 Posts: 164
Enough to carry the desired sail area in a given set of conditions
Regards
Alan
Old 04-20-2008, 08:13 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Catamarans don't need keels, just dagger boards.
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 04-20-2008, 12:18 PM
Nordic Cat's Avatar
Rep: 72 Posts: 164
What's that thing in the picture?
Oh, a daggerboard with a method for setting the depth. Count the bumps??
Regards
Alan
Old 04-20-2008, 06:57 PM
Rep: 10 Posts: 4
hi and thanks for any replys so far.
the reason i ask about the weight of a keel, is that i could buy the hull of a 60foot yacht for restoration, unfortunately the original old lead keel was removed sometime in the past (possibly stolen) and has been replaced with a concrete one which also now needs to be replaced.
Old 04-20-2008, 07:27 PM
Rep: 3125 Posts: 9,398
You can calculate the area with in the dimensions of the current appendage and have a new one made of the material you desire. If using a denser material (a very good idea) then you'll have room to spare in the appendage, which can be "built up" from one of several materials, depending on the yacht, construction type, etc.
Considering the basic nature of the questions, it would be my strong recommendation you contact a qualified designer and have a new appendage calculated up for you. You don't want this things to break off, or affect sailing performance. The location of CG will be moved with a change of ballast materials. With the concrete one in place, I would suspect she's more tender then she was (compared to the "old lead" one) or the appendage was redesigned to accommodate the dramatically lower density of a concrete fin.
What's the worst that could happen right? Well . . . if a new fin was set up for the lower weight material and you just make a new one with a lead filled bottom, then the strains on your rig will increase dramatically, very possibly bringing it down, the first time you have a rough jibe or encounter stiff winds. Call a pro or walk quickly away from this yacht.
Old 04-20-2008, 07:47 PM
Previous Member
Rep: 0 Posts: 0
Tim
Hope you are single. I am guessing that if you are looking at a 60ft yacht that had a lead keel replaced with concrete then you are not wealthy so you are intending to do the restoration work yourself. So if you are not single now, I expect you will be if you take the project on.
OK - So in case you are seriously looking to do this a photo or three would be useful.
Concrete is not a good replacement for lead because it has such a low SG. In fact I cannot imagine how you could replace lead with concrete and have the yacht perform anything like it was intended to.
A 60ft yacht might need 7 tonne of lead or more. At current prices that would set you back about USD20,000.
Restoring a 60ft yacht that is in poor shape is a significant project that will require expensive and time consuming effort.
Rick W.
Old 04-20-2008, 08:46 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Well said PAR and Rick, hope he listens, we all see sooooo many people loose what little they have into dreams that will never materialise.
"The poor man pays twice"
Old 04-20-2008, 09:18 PM
Previous Member
Rep: 0 Posts: 0
The largest yacht I have sailed on was 70ft. This was 30 years ago now and the yacht was maybe 50s vintage. It had been confiscated by customs and three hard working tradesmen went into to partnership in its purchase.
At AUD10,000 they thought they were getting a bargain. In those days you could buy a house for AUD30k. The main sail was a bit tatty so they had it repaired as they could not afford the AUD7k to replace it. Even then it cost AUD2000. They slaved on the yacht for about a year to get it up to sailing condition and spent about another AUD5000 on incidentals like rigging and engine parts.
Two guys eventually pulled out leaving the third guy to hock everything to pay them out and chase his dream. His marriage had failed over the time and money he put into the yacht. Fortunately no kids and his wife just left him for a fellow who thought more of her than a damn yacht - so not cost split.
I sailed a couple of harbour races on the yacht and we clocked 14 knots on a reach. Not bad for a heavy displacement yacht.
He always struggled to find enough crew to sail it. He managed to get enough people interested to sail away for a week but on the first night they struck heavy weather and the planking started to leak badly. They called for help and were towed back by a tug with all effort to keep it afloat.
I am not sure what happened after that but it did stay afloat and sat in the harbour for a long time. I left before the yacht so have no idea where it ended up.
No matter how little you pay for a big boat it is still going to be expensive to operate and maintain. What does it cost to slip a 60ft boat for a week? What does it cost to antifoul a 60ft yacht? What does a mooring cost for a 60ft yacht?
Rick W.
Old 04-20-2008, 10:29 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
We went from what size keel to not being able to afford one.
Actually, a poor man can't afford to keep a 60' boat!
As for dreams, any worthwhile dream always seems unobtainable, That's the definition of a dream. Dreams & an opposing thumb are what separates us from the apes.
Go for it! build that keel...., just as soon as you learn how big it needs to be.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 04-21-2008, 04:20 AM
Ted, you don't think an old ape doesn't dream about a sweet young female to replace his nagging old lady? Please . . . and they have opposing thumbs too . . .
Old 04-21-2008, 09:32 AM
ted655's Avatar
Rep: 122 Posts: 641
Opps! They do, don't they. Well then, it must be the dreams. I nevr met a sailing ape. A few powerboat apes & some PWC chimps maybe.
Sex is JUST sex, but saoling....., now rhere's a dream!!
Old 04-21-2008, 06:08 PM
I've woken up the next morning with one lying on my arm (more then once and how I got my first prosthetic), so I can assure you they dream, probably about someone better looking or more endowed then I.
Old 04-22-2008, 08:56 AM
ted655's Avatar
Rep: 122 Posts: 641
This will get a sharp response, but is there a rule of thumb? Say, 1# of keel for every 30 sq. ft. of sail? I've always wondered about keels myself. Bilge keels, bolt keels, box keels, twin keels, swing keels, shoe keels, lotsa keels!!!.
When I look at a sailboat like a "Spray" design, iy has a power boat keel.
Weight balance. Will it ride better with weight in the rear or dead center? clctrader Boat Design 4 01-24-2008 12:12 AM
wet weight vs dry weight of Diesels... spank Boat Design 3 10-20-2006 03:16 AM
Lead keel weight for sale mvsmith Marketplace 2 05-08-2006 05:18 PM
17 foot boat - sail & keel weight - how much? firsttimer Boat Design 18 09-01-2005 11:00 PM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 01:40 AM
