| Weight Estimate Does anyone have any data on the weight components of a 30m monohull? the weight estime is a relatively important factor to a good design and the one i have done is down 18 tonnes! the vessel is going to be a research vessel, monohull, 10 persons on board. aluminium construction. the structure i have calculated but i know little about more random facets that make up a boat such as the electrics. all i could find was this Thanks for any help offered |
| For example: http://www.fassmer.de/fileadmin/user...Vessel_Web.pdf Also, you could check this page and try to construct a trend line(s) with the data of the existing similar ships: http://www.researchvessels.org/ship_...2=Begin+Search Once you have a trend line, you can interpolate your vessel's case, with healthy +/- margin. |
However, you need to be a bit more specific....what type of 30m monohull...L/B ratio plays a part...as does speed...so does which rules and regulations....payload....what is the SOR etc etc. Otherwise it is like comparing a mini with a ferrari..they both have 4 wheels, both are cars both carry passengers etc.... This "simple" mono hull, of 30m LOA has the following: Group 1 Hull = 24 tonne Group 2 Propulsion = 10 tonne Group 3 Electrics = 4 tonne Group 4 Comm. & Control = 1 tonne Group 5 Aux. Systems = 6 tonne Group 6 Outfit = 8 tonne Group 8 Fluids = 0.5 tonne Margin 5% = 2.5 tonne So the total lightship is around 55 tonne. This is for a mono of L/B =5 Top speed 25 knots Carrying 35 tonne cargo. This might help.. But you wont get too many weight sheets available publically. |
| research monohull, specs are LOA = 30 BOA = 6.7 Tc = 1.8 top speed = 20 knots displacement = 123 tonnes. Aluminum hull and superstructure IMO and SSC |
| The figures i quoted above the full load is 120tonne, so similar to your 123 tonne. Big differnece is the machinary...more than double...so that can't be correct!...and a crazy amount of fuel too. Otherwise rest is not far off. |
| I'm sorry, didn't read your post correctly. You were actually asking for a weight breakdown, while the links above give only total operative weight of different ships. My fault ![]() |
| Just done a design now and completed the construction of a 30m Patrol ALU boat. view www.navaldesign.co.za They weight (Full displacement) came in at 110 T.
__________________ Kobus |
| ======= Yes, he is: 22-2011, 07:41 AM Farley Junior Member Join Date: Jan 2011 Rep: 10 Posts: 15 Location: Austria I have been set the task of analysing a sailing yacht's keel using a program my lecturer has made ( it uses ISO 12215) For this I need information about a specfice model/yacht's keel configuration.
| It can be anything. What you have to do, is list every component, including accessories, water, fuel, etc. and add it all up.
__________________ Gonzo |
| *****The student *** ---> No star where ! --- www.strategicmarine.com |
| How to estimate a boat's weight ? | Trevano | Boat Design | 6 | 08-25-2008 12:33 PM |
| Weight balance. Will it ride better with weight in the rear or dead center? | clctrader | Boat Design | 4 | 01-24-2008 12:12 AM |
| Materials Estimate? | mtnrat | Fiberglass and Composite Boat Building | 0 | 05-10-2007 08:47 AM |
| wet weight vs dry weight of Diesels... | spank | Boat Design | 3 | 10-20-2006 03:16 AM |
| Average Human Weight, Safe Excess Weight, &c. | Free Pirate | Boat Design | 12 | 03-14-2005 01:40 AM |
