Old 02-02-2007, 09:14 AM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
The LM-2500 turbine engine used in Spruance class destroyers is a split-shaft turbine. The jet engine is not connected mechanically to the power turbine - the jet thrust blows on the power turbine's blades to turn the propeller. This means the engine can stay revved up at full speed all the time. It also means the ship can go from cold to hot in 15 minutes, as opposed to about 6 hours for steam turbine ships.
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Old 02-02-2007, 10:06 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
yes, one gasturbine on a single or double shaft out? or have two gasturbines? CR props? than whats stem or stern?
have the turbine(s?) blow through elbows or would a V drive box do better? ventilate the running delta and/or props with augmented exhoust gasses?
want a 90.000 or 12.000 rpm jet? a 200.000 or 10.000 $ ? and more considerations Marine Gas Turbines and Marine Gas Turbines
ahh help
Velvet Drive Linkage and Prop shaft leak suprasport Inboards 2 09-07-2006 11:07 AM
Steering problems on turbojet hydroplane FranklinRatliff Boat Design 0 03-07-2006 11:42 AM
Drive Ratio and Prop Pitch rayjay Powerboats 3 04-22-2004 02:07 PM
jet drive v/s prop. big cat Boat Design 8 05-19-2003 09:08 PM
Combine Power output or not? Inerested Powerboats 3 08-15-2002 01:19 PM
