Old 10-23-2005, 07:34 AM
Hisham Hisham is offline
Marine engineer
Rep: 28 Posts: 45
waves on pontoon structure
I am designing a pontoon, the left side hull and right side hull will be connected to gather at the stern with a transverse steel bars or truss
I know that in mono hull ship, the critical waves stress is sagging and hogging
So where can I fiend a good description of wave stress act on pontoon or catamaran
Old 10-24-2005, 01:03 AM
KCook KCook is offline
Rep: 13 Posts: 171
As a practical matter, on small (24 foot) recreational pontoons, the main trouble is twist. One side rises for a wave out of sync with the other side. Sorry, don't know of any studies quantifying this.
Kelly Cook
Old 10-24-2005, 04:52 PM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
I would make some kind of allowance for flexing. The port hull may be climbing up a wave whie th starbord hull may be coming down one. With steel connecting beams, I would use some kind of compressable bushing under the connecting beams. Otherwise, I would have to worry about metal fatigue at the connecting joints.
Either that or I would make the structure so rigid that it would hardly flex at all. This could be done with a large, thick box beam in the form of a wing deck.
In a matter like this, experience is everything.
Bob
Old 10-24-2005, 08:42 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
A truss will not flex. A better design would be a torhsion bar. Or a walking truss, hinged in the middle, but under a type of tension by some device (spring?) to return the truss to normal surface rigidity.
Rogue Waves brian eiland Open Discussion: All Things Boats & Boating 104 08-02-2008 01:00 PM
pontoon boat parameters: basic sources? helipilot Boat Design 5 08-21-2005 11:29 AM
Pontoon design and level sitting angle billpitts Boat Design 0 07-27-2004 02:00 AM
center pontoon on houseboat hboat Boat Design 0 05-05-2004 10:16 PM
Boat Propelled by Waves Energy Kneider Boat Design 5 03-23-2004 05:54 AM
