Old 11-11-2003, 05:29 AM
asterix
wave making machine
Can anyone help with information on wave making machines that will operate in the sea using a bladder as apposed to a hydraulic system.
Old 11-11-2003, 09:35 PM
MDV MDV is offline
Rep: 60 Posts: 31
You need to move the flap in both directions, so when using a bladder you will need one on each side. The other option is springs etc.
The use of hydraulics is in my opinion the best, especially in terms of having total control over the generation of the waves. The force, speed and position and hence the properties of the generated wave can be controlled with modern electronics and PLC's.
Hydraulics will be more reliable and easier to maintain, especially if you use ones specially designed for use in or around seawater.
If there are issues of pollution from spillage of hydraulic oil, then the other option is pnuematic cylinders, although for a given size they will have less power.
Why do you want to use a bladder?
Michael
Old 11-12-2003, 05:48 AM
asterix
Wave making machine
Hi Michael,
My thoughts were based on cost as I was looking at a length of 300mtrs and a wave height of 2mtrs.
If air could be pumped into a bladder envelope that would open and calapse disturbing the water creating the wave.
Any thoughts on capturing the energy from existing sea swell and
storing or redirecting.
regards Asterix
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
saling catamaran wave making pops Boat Design 2 08-08-2004 11:11 PM
Calculation of wave resistance and potential flow. yipster Software 12 03-17-2004 08:59 PM
