| Water ballast construction Hi all..... I'm building a "hard tank" setup in my ski boat for filling with water ballast to make the wake bigger, looking at building fibreglass tanks capable of holding 400lbs. Do I need to make these tanks out of vinylester resin or will polyester be fine? as this is not potable water. Bearing in mind that water will not be sitting in the tanks for any long period of time only when wakeboarding. Cheers Mat |
| Yes you can do it with poly. Remember gelcoat on both sides and fasten the tank well in its place. Just make also strong baffles inside. Make sure all the plumbering is marine grade and properly installed ![]() |
| As an addition to TeddyŽs comment: doŽnt forget a sufficient "manhole" to clean the tank from time to time, you otherwise host a biotope after a while. Regards Richard |
| cheers for the advice guys, do i need gelcoat both sides? if at all? just curoius? also what is biotope? |
Regards Richard |
| Water Ballast | goolawah | Wooden Boat Building and Restoration | 6 | 10-30-2005 08:43 PM |
| Water Ballast & Keel Ballast | jag459 | Sailboats | 4 | 09-08-2005 01:39 PM |
| Water Ballast vs Keel Ballast | jag459 | Boat Design | 13 | 09-08-2005 07:01 AM |
| Water Ballast | Guest | Boat Design | 17 | 09-30-2003 01:50 AM |
| Fuel, water, black water tank construction | kudu | Boat Design | 12 | 07-25-2003 06:54 PM |
