Old 09-19-2008, 11:11 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Waratah; Fitting out started...
For those whom have asked for an update on the Dix 43 under construction; yes we are still going strong and spent some time on the following since last posted.
4000kg lead was poured in the keel and sealed. Then all holes, supports etc etc were cut and weld into the hull as needed for fitting out. The hull then received a second coat of epoxy primer, two coats of brown epoxy on the inside followed by a white Ceramic thermal insulation paint, applied in two thick coats.
Tanks were sorted out and sealed and the bulkheads are going in as now. Bad thing is the fact that the panels have to be cut down to fit through the companion way, and rejoined inside the hull again and that takes some time.
The first deck fittings went on deck and by next week she will look like a boat on deck. BTW, the deck now sports a grey colour that is the tie coat between the primer and top coats to come.
We stopped work for a week recently and everyone were used to get the new factory together we had acquired next door for our fibreglass production boat we just started tooling now.
Some interesting facts about the epoxy paints used on the boat thus far.
Epoxy primer used in total - 120 liters
Epoxy Coal Tar base coats - 35 liters
Epoxy grey tie coat - 15 liters
Ceramic thermal insulation - 80 liters
Epoxy thinners - 35 liters
Epoxy Fairing filler 12kg effectively on hull and deck
Waratah; Fitting out started...-fitting-out7.jpg  Waratah; Fitting out started...-fitting-out-13.jpg  Waratah; Fitting out started...-fitting-out-11.jpg
Waratah; Fitting out started...-fitting-out15.jpg  Waratah; Fitting out started...-fitting-out-027.jpg  Waratah; Fitting out started...-fitting-out-10.jpg
Waratah; Fitting out started...-fitting-out-033.jpg  Waratah; Fitting out started...-fitting-out-043.jpg  Waratah; Fitting out started...-fitting-out-044.jpg
Wynand
A scatterling of Africa
Old 09-19-2008, 01:11 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1474 Posts: 1,620
Beautifull
Beautifull
Beautifull
please tell us what is going to happen "next door"
are you starting to build your little sailer for you and the missus????
Old 09-19-2008, 01:12 PM
Manie B's Avatar
whats up doc
Old 09-22-2008, 12:40 AM
Wynand N's Avatar
Manie, we are getting ready to tool the 6 meter trailer/day sailor I had designed recently after toying with the idea a couple of years now.
She is very similar to the Melges 20, but the transom is totally different and sports a small cabin for occasional sleeping space for two people. The keel retracts vertically and ballast is on a bulb on the tip. Draft varies from 0.4 - 1.5 meters and with the keel up, easily to load and launch from a trailer.
Unlike the Melges, she will have no carbon fibre mast, spinnaker pole, etc, but aluminum sections instead. Then again she will cost considerably less than the imported Melges...
Finally, she was designed with no rule in mind, other than to be a fast, safe and fun boat, with the emphasis on affordability.
Wynand
Old 09-22-2008, 07:22 AM
Manie B's Avatar
Best of luck with the new build
Melges sure are purdy
http://www.melges20.com/
hopefully you could export them
our bloomin folks are too lazy just to even go to the dam
Waratah - Dix 43 CC Wynand N Metal Boat Building 4 01-31-2008 11:01 AM
getting started rlmccook54 Wooden Boat Building and Restoration 14 11-02-2007 01:26 PM
Fitting keels eillew Boat Design 0 04-01-2006 12:43 PM
just getting started. raysmith480 Open Discussion: All Things Boats & Boating 3 11-09-2005 02:28 PM
Just getting started. ghmurphey Wooden Boat Building and Restoration 2 06-27-2004 08:29 AM
