Old 09-21-2011, 09:44 PM
tr3y14 tr3y14 is offline
wanting to build a fiberglass flat
Where can i find plans to build a fiberglass flat like the one in the pictures, thanks
Old 09-22-2011, 09:54 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
how about
http://www.bateau.com/proddetail.php?prod=FS12
or another of the designs on their site
They are plywood, but would be lighter than a fully fibreglass version in most cases
Old 09-23-2011, 05:43 AM
Rep: 670 Posts: 2,457
Google search....duckboat, Garvey, flats boat,
http://store.devlinboat.com/honker.aspx
wanting to build a fiberglass flat-honker1.gif  wanting to build a fiberglass flat-honker3.jpg
Old 09-23-2011, 12:18 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
tr3y14,
Plywood is stronger, lighter and stiffer. The latter makes it ideal for flat bottoms. You can build a bigger boat, power it w less and build it much cheaper. Don't even need any FG on the bottom unless you're going to run it up on bad jagged rocky beaches. Look at PAR's Digger. One tough boat.
Old 09-24-2011, 01:28 AM
Rep: 3125 Posts: 9,398
Off the top of my head, I don't know of any single skin 'glass designs like this, but I could be wrong. There are likely a few foam cored 'glass designs in this size, but this is a more costly way of building a small boat, not to mention you have to enjoy sanding and itching. My Digger 17 would be well suited for your needs, but it is a plywood boat. It can be sheathed in 'glass if desired, but it's not absolutely necessary. The sheathing is good for abrasion protection though, especially if Xynole instead of 'glass is employed.
Wanting to build a fiberglass box using shell as mold? vincent9993 Fiberglass and Composite Boat Building 6 04-02-2009 07:06 PM
Wanting to build a Power 20'-22' TRI ncstriper Multihulls 0 03-04-2008 07:07 AM
Wanting to build my own boat. newsmyrnaslayer Boat Design 7 01-24-2008 11:33 AM
Wanting to build an upside down boat dgie Fiberglass and Composite Boat Building 14 09-17-2004 05:29 PM
Fiberglass Flat Panels: Sources needed BillB Fiberglass and Composite Boat Building 6 08-05-2004 10:57 PM
