Old 12-25-2004, 10:28 PM
horleywood horleywood is offline
Wanted: bluewater steel sailboat plans
I am wondering if anyone out there has a good set of plans for a steel bluewate sailboat liveaboard in the 30 -45 foot range, diesel powered, sloop design preferred.
Lloyd
Old 12-26-2004, 03:03 AM
B. Hamm B. Hamm is offline
Registered
Rep: 16 Posts: 97
30 to 45 foot range?? Might try narrowing that down a tad, that's a huge range of size.
Bill H.
Old 12-26-2004, 06:24 AM
Rep: 700 Posts: 3,207
Plans are purchased from the designer for ONE TIME USE.
Passing on plans is stealing from the designer ,
same as taking his TV out the back door.
FAST FRED
Old 12-27-2004, 06:33 AM
If you are interested in a NEW bare hull (saves about 2 years of construction) and miles of welding , sandblasting ect!! E mail me.
The hull is steel designed & owned by Merrit Walter ,
who normally designes boats to USCG speks to carry pax for hire.
Strong & well built she is 45loa Schooner about 40 lod , 32.6lwl draft 4.6 beam 12.6 Sail 801 sqft with 30,400 disp.
The sort of vessel you sail to the far corners of the earth with , not worring if a crew member had the audacity to bring along a full tube of tooth paste , as compared to the "racers" where "Excess"weight is DEATH.
FAST FRED
Old 12-28-2004, 07:06 AM
tschienque tschienque is offline
Registered
Rep: 10 Posts: 33
I nearly went with George Buehlers "HERA" design http://www.georgebuehler.com/Hera.html a particularly salty looking 39',
before deciding a catamaran was better for me in the short term (been 14 years so far).
Steel Yacht Plans sought aitchem Metal Boat Building 9 10-03-2005 11:47 AM
Please recommend sailboat plans jmwalker Wooden Boat Building and Restoration 9 08-16-2005 04:38 PM
Steel plans needed for 15 metres hull Jon E Services & Employment 2 01-10-2005 06:10 AM
70ft+ steel , cheap plans genesis Boat Design 23 12-28-2004 07:19 AM
Steel sailboat mast Gerald Niff Boat Design 4 08-11-2004 07:10 AM
