Old 01-08-2007, 12:59 PM
LinedTheBlind LinedTheBlind is offline
Rep: 10 Posts: 13
Want to add steering console to TDB duck boat
Hey. I'd like to get input from any boat building experts or amatuers about installing steering on a 14ft Classic TDB (see attached). I need a system that's compact as possible (for decoy storage) and that doesn't stick up above the gunnel or folded down (so the top can be placed on). The boat has no steering or power cntrols now..i've got a manual tiller outboard. I'd like to make this change becuase it's difficult to reach out of the boat to raise the motor when running in the shallows and want to move my weight towards the bow. thanks.
Old 01-08-2007, 01:10 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
It might be easier to put the motor in a well, closer to you and further forward.
Steve
Old 01-08-2007, 01:38 PM
Rep: 593 Posts: 2,054
Go to the Stick
You can build a simple, stick steering system for the boat with quick release connectors at the engine for easy transport. Here's an example of a commercial rig: (It should be pretty simple to build one of your own for a lot less cash.)
http://www.nicksoutboardmarine.com/steeringpg6.html
Old 01-08-2007, 07:20 PM
tja tja is offline
Rep: 11 Posts: 125
Tja
He can't move the motor forward as there are flotation boxes and other structural components to the boat that should not be altered. The stick steering would be the best option as there isn't really enough room in the cock pit for a steering wheel. If the stick goes above the cockpit cover just cut a slot in the cover to let the handle through. Good luck.
Old 01-09-2007, 04:38 PM
RAWRF RAWRF is offline
Rep: 14 Posts: 72
Have you thought about using foot controls for steering like the ones that operate the rudder on kayaks? These are super simple. You don't even need pulleys, just strong cord or cable, I used to use starter cord on mine because it is very strong with low stretch potential and ran it through plastic tubing at bends and wear points.
Old 01-09-2007, 04:50 PM
Rep: 10 Posts: 13
thanks for the input. my one big concern regarding stick steering (with remote throttle) is that it requres two hands (vs one hand for tiller motor). When running my current set-up, i usually have the tiller in one hand and the spot light in the other for the early morning duck hunts.
Old 01-09-2007, 05:10 PM
Perhaps you could assemble a list of the limitations, advantages and dream scheme desires so we have a stationary target to shoot at. Otherwise, this becomes a guessing game akin to, Is it animal, vegetable or mineral?
I'd be interested in offer-up some concrete solutions for you, but there seems to be a list of stuff, as yet undisclosed, that just pops-up to change the paradigm of the thought process.
Old 01-10-2007, 12:21 PM
Rep: 10 Posts: 13
Chris, thanks for your help.
Old 01-10-2007, 07:30 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Some motors have tiller extention kits.
When you do go to a steering system, you'll have to tuyn loose of the tiller anyway. So lets just change rhe topic to "remote" operation and solve it. Even then, lifting the motor is still not addressed. There are going to be trade offs, decide if they're going to be worth it.
Now go take a look at "Surface Drive" on this forum. Google some and see how Gator Tail, ProDrive, Go Devil & a couple others do it.
( they use a modufied starter motor and a mini winch drum ) Their other remote control stuff is fairly simple.
Add it up, maybe cheaper to buy one of their smaller motors. THEN you can run in 2" of water no problem cher.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 01-11-2007, 05:59 AM
alaskamokaiman alaskamokaiman is offline
Rep: 13 Posts: 59
Look at Mokai.com they have steering and throttle all in one. I own 3 and just love these little boats.
Old 01-11-2007, 08:44 AM
Rep: 10 Posts: 13
Ted, I'm familiar with mud motors like go devil and while those with the tiller extension would allow me to operate from the front of the boat, it would also get in the way of passangers and large decoy bags stowed behind me. While I think mud motors are great, I don't think it's the right choice for this boat. Thanks.
MokaiMan, I had a long hard look at the mokai boat before i bought my first duck boat. decided against it due to small size and all the shallow muddy areas that i get into. Mokai said the jet motor doesn't do well in such areas. But their combo steering/throttle may be just what i'm looking for. I'll definately look into it. thanks.
Old 01-14-2007, 08:41 PM
ted655's Avatar
Rep: 122 Posts: 641
===="Ted, I'm familiar with mud motors like go devil and while those with the tiller extension would allow me to operate from the front of the boat, it would also get in the way of passangers"=====
Then you aren't familiar with the NEW style mud motors. NO tiller. They are JUST like a OB. Steering wheel, tilt and trim, electric start. Been a few years since you visited a webpage? Give a look
center console with steering and throttle $250 7393452 Marketplace 0 12-20-2006 04:14 PM
duck hunting boat?? hoobilly Boat Design 8 11-18-2006 08:01 AM
Marsh Duck Boat kaioken Boat Design 5 06-22-2006 06:32 PM
Redo Steering Console DLR Fiberglass and Composite Boat Building 1 06-30-2004 03:45 PM
Check this boat out and add your comments... ErikG Sailboats 5 03-31-2002 09:06 AM
