Old 07-06-2005, 10:06 PM
lmorgan30 lmorgan30 is offline
Rep: 10 Posts: 11
volvo penta 200d starting in the water issues
I have a 1968 chris craft with a volvo penta 200D out drive and when I start it in the water it will run for a few minutes and then flood out and die when I try to restart it it will not start and drags is there something internally that is letting water create backpressure? I would appreciate any help!
Thanks Les
Old 07-06-2005, 10:27 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Fuel pump problem? Maybe carb jets are set wrong? Try taking your boatyard's mechanic for a quick cruise. Back pressure in water lines shouldn't be able to stall a motor.
(Just making sure- by 'flood out' you do mean flooding the motor with fuel, not with water, right?)
Old 07-07-2005, 07:43 PM
Rep: 1397 Posts: 7,216
If it is water, the exhaust riser would be my first guess.
Old 07-07-2005, 08:13 PM
Rep: 10 Posts: 11
200d
it is flooding with fuel in the carburator
Old 07-09-2005, 12:19 AM
Rep: 10 Posts: 11
it only does it in the water
Old 07-09-2005, 12:21 PM
So if you run it on a hose until it is warm there is no problem? Also check the bypass on the fuel pump. If the primary diafragm broke, the leaking fuel is dumped into the intake manifold. It is ( or should be) a clear 1/4" plastic line.
Old 07-09-2005, 12:25 PM
Rep: 10 Posts: 11
ok i will try and get back to you
Old 07-16-2005, 12:29 AM
Rep: 10 Posts: 11
fuel issue
I had a friend of mine come over and we took a look at my carb i had rebuilt and it was leaking fuel while sitting.I also have fuel in my oil so I have to have them look at my carb again and make some adjustments will keep you posted!
Volvo Penta SP drive no reverse Bragg Brothers Sterndrives 5 08-10-2011 11:46 AM
epoxy fuel tanks Boatbuilding 24 08-14-2008 04:36 AM
Loss of power on a Volvo Penta Lounger Powerboats 4 08-04-2005 06:10 PM
volvo penta 200 outdrive noise cmzracing Propulsion 2 01-02-2005 04:48 AM
