| Vessel Security! How to remote disable a yacht! Heres a question for you serious designers of blow boats! If an owner of a big blow boat wanted to install some kind of remote activated alarm system to track their boat in the event of it being stolen and then remotely 'disable it' to allow authorities to intercept / recover same - how could such a system work! OK - with a power boat you might fit a electronic servo / relay that cuts ignition - but how does one disable a sailing vessel? Someone has nicked your 60 ft cat or monhull sailer and is headed for the open sea & eventually New Zealand! Just what can one do to disable a sailing vessel - by relays / solenoids that can be remote activated? There are a heap of available security / alarms systems for vessels (power boats) and some are GPS GSM cellular network activated, some are sattelite activated etc and some track and some send CCTV video of the perpetrators etc...so I'm not asking anyone to invent a alarm / secuirty system - it's already been done - just wondering what one could do to a yacht via these systems that might render it inoperable (send it in circles?) so it can be stopped / recovered? Any bright idea's? Cheers! |
| If the thief knows what he is doing it would be hard to stop him. Even if you disable the electric or hydraulic systems for winches and steering, if fitted, you can work around that. A sailboat does not depend on electronic systems very much. Robert Gainer |
| Use a system like a deadlock on a household door. The lock can be pushed in to stay open, and then when the release button is pushed the lock springs out and can only be opened with a key. This could be set up on the rudder shaft. |
| Maybe something that would disconnect whatever you call the line/rope that hauls the sail up the mast. A pin or something that would pull out and let loose the anchor point of that line. At the same time the engine would also have to be disabled. If you disable the rudder it would seem to endanger the boat as it couldn't be steered away from predicaments. Sam |
| explosive keel bolts
| People or criminal that wanna steal boat and ship are high tech bunch and would already have mean to see this idea comming........... best way have your muscle newphew stay at the boat house with a water spear. ![]() |
| Large boats in Oslo have a transmitter hidden inside and the alarm goes when the boat exits the fjord. This works when you are in a fjord with one narrow exit. |
| Exploding Keel Bolts and Mast Step! Trust me I like the way you guys think! Unfortunately I guess owners of said vessels might not concur! I see merit in the removable pin / sail hoisting idea and Also a deadlock rudder arrangement...they turn one way or another and the rudder "jams" in a circle! As is pointed out, not much on a yacht depends on technology or electronics these days! An interesting conundrum all the same! How about "self detonating mast stays fixings" so the vessel dismasts itself? Still open to idea's.. Cheers! |
| Yeh................ put exposed electric cable around the ship and ask your mother-in-law for a cruise ,just in case it doesnt work with the thieves. |
| Release a cansiter of obnoxious gas, such as mercaptan in the cabin. Activate a circuit connecting a 12 volt fence charger to the helm. Activate a program in an electronic autohelm to steer into a circle. Activate an epirb hiden in the boat, also horns and lights to draw attention. All of these could be by passed, but if the crook is unknowing, thye should be a deterrent. |
| Take your sails and steering wheel home with you. Works for me.
__________________ Just........Swanning around |
| an easier system is a tracking system with for instance GPS/GSM triband. Doesn't work on open ocean, but works when comming closer to the coast. The system exists for other expensive stuff and is smaller than a beer can. downside for cars is the lack of abillity to work through steel. so when you put a car in a 30ft container, your out of reach long enough to track the tracking device. One good point, most ships don't fit in a container....
__________________ |
| I Like It! Ha-Ha!! As I was scrolling down I was thinking, How about explosive sidestays!!?? Then I saw Tom's post!! Too cool, great sense of humor! Made my morning, Tom. I once had my leeward sidestay coil up on deck on an M-16....it seems the ringy dingy wasn't in the pin on the mast... results in instant realization the mast will come off if you tack. Also instant realization the main sheet is the only backstay on an M-16! ![]() |
| Activate a circuit connecting a 12 volt fence charger to the helm. Indeed! I think this is GOOD latteral thinking! Qute workable in all probability! Maybe off topic but it reminds me of something I read recently i thought I'd share! Quote:
Fence charger - taysar... You have me thinking now!!! Cheers! |
| Vessel security patrols! | trouty | Open Discussion: All Things Boats & Boating | 59 | 02-15-2006 12:00 AM |
| Remote control boat | warlordseven | Boat Design | 17 | 09-07-2005 03:07 PM |
| Safe Remote Fuel System for boats | tom kane | Open Discussion: All Things Boats & Boating | 7 | 04-04-2005 11:36 PM |
| Specing out a new vessel | Guest | Fiberglass and Composite Boat Building | 1 | 09-20-2004 06:08 PM |
| want a new vessel? | THERIAULTMARINE | Press Releases | 0 | 08-28-2004 01:55 AM |
