Old 05-20-2005, 09:24 PM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
Very sensitive planning pads / and slime
Cute syndrome of my boats planning pad and slime. Boat out of storage does 54 mph at a rev limit of 4900 rpm. 6 months later it only does 48 mph at 4800 rpm and can not reach the revlimiter. Can a boat and drive be factory setup that close to cavitation, so a 1/2" of the soft green slime causes cavitation and that much difference?
Old 05-21-2005, 09:50 AM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
Probably not cavitation so much as the drag caused by the slime.
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 05-21-2005, 11:21 AM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Goop...
Hello...
Small solids into the prop wash...
What...
Sounds crazy - but at a bazillion RPM who knows what the F'un sunny day is going on...
The 'good old boy' answer is yup...
SH.
Old 05-21-2005, 12:09 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
not beeing "cavitation" implosions at the prop i belive we talk "ventilation" or even another named fenomenen...
Old 05-21-2005, 02:30 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 512 Posts: 1,032
I don't know if you have tested the boat on the same way, because I've noted that the planing boat go faster in shallow water, opposite for semidisplacement or displacement boats, they go slower.
The drop in speed is of 11 % and the revolutions loss only 2%.
The propeller absorbs the less power at same rpm.
Control the blades of the propeller, perhaps one has taken a blow.
RANCHI OTTO
Old 05-21-2005, 04:29 PM
Thanks Ranchi. The Prop Shop owner is doing a full blown base line check and power runs, clean and then when I get down to the 40's. I always run the WOT in the same place at sundown calm.--------------------------------------------------- At the " clean 54 mph conditions" I can not cause a prop " blow out " under any condition. At the " slimy 48 mph condition" I blow the prop out at any speed from dead slow, to 40 mph, just by applying a very fast full power.-----------------------I think I am doing some snorkeling this summer
Old 05-21-2005, 06:02 PM
artemis artemis is offline
Steamboater
Rep: 267 Posts: 411
Suggest you haul her and clean the 1/2" of gunk off the bottom.
The "softness" of the slime and the surface irregularies could easily account for a 6mph drop in speed (and I wonder how much that slime weighs?)
Old 05-21-2005, 09:10 PM
Everybody: I remember reading of a very slick coating the Offshore boys use on the bottoms. Something spelled like K.I.S.S. a organic coating that is super slippery. Do you know the name of it?
Old 05-22-2005, 04:36 AM
yipster's Avatar
did read about it but cant come up with a name. it was a messy sort of low cost cowfat thing, better use speedo anti fouling.
i lost some rpm in deep seawater, thought it was the salt or temperature but shallow vs deep water is most likely the scientific reason.
Old 05-22-2005, 12:49 PM
Steamboater
Rep: 267 Posts: 411
Weight of "gear" aboard
What is the weight of the "gear" (food, bedding, clothes, tools, odds 'n ends) that you take out of her before storage. What is the weight of the gear put aboard at time you take her out of storage. You'd be amazed at how much "stuff" accumulates in 6 months of cruising - and it all weighs!
Old 05-22-2005, 02:43 PM
Hopeless Boataholic
Rep: 173 Posts: 604
Now you're cookin'
Ditto on that. I just emptied out my 26' Chris Craft after hauling her out for the year (gas prices ). It took me nearly 3 hours to get the stuff out and sort it (there's that %#@!! chart! ). Probably around 400-500 lbs. worth.
Craig Cavanaugh
Old 05-23-2005, 02:32 PM
I remove or add nothing, except myself. Always stored with a full tank of gas.
Old 05-23-2005, 04:25 PM
Naval Architect
How much did you have eaten in the last 6 months ?
What about your actual weight ? Always the same ?
RANCHI Otto
