Old 07-11-2016, 08:03 AM
NicoARG NicoARG is offline
Rep: 10 Posts: 4
V-bottom planing hull design
Hello guys ! Im new here and im looking for help at the design of a 24' planing hull.
The idea is a semi-oceanic boat with a deadrise arrown 10 and 15 degrees with a deep V at the bow.
If someone have some plans to start drawing or some information i will verry grateful !!
To be more especific, the craft im designing is a Aluminum Landing Craft.
i leave a image of the craft i want to modificate to a hull more "marine" with a deadrise of 20 al the transom. and a V shape at the Bow.
Old 07-11-2016, 08:58 AM
Satan Satan is offline
Designer
Rep: 10 Posts: 44
I will suggest you to have a high value of deadrise over 20 degrees to have more dynamic stability in rough wave condition . I know that increase the roll and fuel consumption but i believe that is important if you want a good seakeeping in Ocean.
Old 07-11-2016, 09:03 AM
TANSL TANSL is online now
Rep: 300 Posts: 3,902
Probably I could colaborate with you. What you need: delineation, naval architecture calculations, scantlings, construction drawings, ... ?
Please e.mail me if interested, to clarify the type of help you are looking for and to exchange information : 657677483@orange.es
Old 07-11-2016, 07:14 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,895
I disagree with the need for high deadrise, unless this boat has a high top speed goal in it's SOR. You have to sacrifice quite a bit with 20+ degrees of deadrise, which is only tolerable on certain and specific SOR targets.
A 24' near coastal cruiser, with occasional romps in deep water designs abound and about every design firm has some to select from. Check with Glen-L.com, Bateau.com and the other usual sources.
This is one of mine and well proven.
Old 07-11-2016, 10:39 PM
Mr Efficiency Mr Efficiency is offline
Rep: 677 Posts: 5,372
To be built in what material ?
Old 07-12-2016, 06:06 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1749 Posts: 4,913
28 feet
Trailerable
Planes at 16 knots, 22 knots top speed on 70 HP Outboard
For every action, there is an equal and opposite criticism. "
Old 07-12-2016, 06:23 AM
NicoARG, as you can see, everyone, trying to help, tries to show the boat from his portfolio that believes best fits your needs. So it would be very important to you to do a better description of what you're looking for.
rwatson, you have progressed a lot with your 3D models. Congratulations.
Old 07-12-2016, 07:42 AM
Rep: 10 Posts: 4
in Aluminum !! its a landing craft to be more especific.
Old 07-12-2016, 07:51 AM
Rep: 10 Posts: 4
Originally Posted by rwatson View Post
28 feet
Trailerable
Nice boat !!
I expand the description of what im looking for but i will have your design in mind !!
Old 03-01-2017, 11:13 PM
sahad sahad is offline
rwatson, I have some skills in sheet metal work. Very keen on your 28 feet planing hull design. Visually, your design makes an excellent statement. I would like to execute it in steel. What stage are you at right now?
Old 03-02-2017, 03:20 PM
Rep: 1279 Posts: 2,651
Please be a little more specific about what you mean when you say" Landing craft"
In the usual parlance, a landing craft is a boat that is a cargo carrier or troop carrier capable of powering up onto a beach while retaining the ability to get itself off the beach unassisted. A deep vee is questionable for such a purpose.
Old 03-02-2017, 04:27 PM
See picture in post #1. That's exactly a "landing craft", imho. A deep vee is questionable for such a purpose, so vee cant be deep.
Old 03-02-2017, 07:36 PM
Tanton Tanton is offline
Rep: 294 Posts: 987
Garvey
Landing craft.
V-bottom planing hull design-324a2-nr15-13.jpg  V-bottom planing hull design-324a3-nr15-13.jpg  V-bottom planing hull design-324a1-nr15-13.jpg
Old 03-02-2017, 07:57 PM
Tad's Avatar
Tad Tad is offline
Boat Designer
Rep: 2281 Posts: 2,272
Specmar does these using a vee bow section and then cutting the tip of the vee off aft to form a zero deadrise pad.
http://www.specmar.com/aluminum-boat...ing-craft-1331
Old 03-08-2017, 04:19 AM
Sailcy Sailcy is offline
Rep: 10 Posts: 63
rwatson very sleek looking boat! Could you tell a bit more about this design please?
Pressure sensors for measuring pressure field on the bottom of the planing hull? Binze Hydrodynamics and Aerodynamics 16 04-17-2014
03:44 AM
Basic planing hull design RJGoodhead Boat Design 9 04-27-2010
02:19 PM
Help with planing hull design ringoo83 Boat Design 5 12-02-2008
11:39 AM
Planing and V Hull Design smjmitchell Boat Design 0 01-24-2006
11:06 PM
Skiff bottom, planing hull, Okume plywood??? Carlito's Boat Design 1 09-15-2005
10:28 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
