Old 08-02-2008, 02:00 AM
bahgota bahgota is offline
is using FPP with fire pump and shaft alternator on maine engine's PTO possible
Hello, I'm facing a problem,
we are supposed to build an ASD 31m work boat for fire fighting, supply, towing, berthing and unberthing
but the client wants a FPP and diesel driven fire pump and a diesel driven bow thruster
which we thought of fitting the Firepump on the main engine PTO and use an elecrtical bow thruster instead, and fitting a shaft alternator with higher rating than that of the boat's genset to compensate the electrical load increase,
but the problem, is it possible to fit a FPP to and engine having fire pump and shaft alternator mounted on the PTO of main engine because of speed variation,
or better to use CPP with Engine configuration and PTO genset for powering the bow thruster.will this combination would be more trustable and less maintenance.
please Advice
Old 08-02-2008, 08:26 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
bahgota,
The vessel is obviously going to be in class survey, the customer request is to survey requirements, the fire pump is to be independant of the main engine, actually two are required in most cases.
Why would you want a CPP when the customer has asked for FPP? What the customer has asked for is normal..PTO driven fire pumps are not primary, but could be secondary pumps anyhow. As the boat is only small, the main engine may not even be able to power that much from PTO's anyhow, check with the manufacturer about PTP taleoff power and loading vectors.
Your last question about reliability....no, the redundancy factor is higher, maintenance is a marginal cost as the society determines the rules, the independant power source has to be there anyhow.
PTO/PTI mode with engine running... ideaEngineering Boat Design 7 12-08-2009 02:11 AM
Any laminators looking for work in Maine? Figmental Fiberglass and Composite Boat Building 1 01-20-2008 05:06 PM
Small-scale PTO JPC Propulsion 2 12-22-2005 09:46 PM
Dual engine's -- one prop? TinyMan Propulsion 13 11-10-2005 07:42 PM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 08:02 PM
