Old 10-24-2011, 09:01 AM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 460
Here's a link with some background info.
http://www.blackfinforums.com/sites/...fjsepoct08.pdf
Fair winds & calm seas
Old 10-24-2011, 11:42 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Interesting piece of history you linked to. I actually sold marinium hardware to RAJ when they started up and later to Blackfin when they were in Port Everglades.
I am familiar with the Blackfins and I believe you will find that the tabs are " pocket mounted" and of a very long chord (fore to aft dimension) because of the limited transon space taken up by the prop tunnels. This is because the boat needed more tab than the transom allowed for with standard chord tabs.
There are trim tab "tricks" to increase lift / area but I would need more details.
As you mentioned, these hulls were not originally designed for the power / weight you are considering.
I have found that as vessels age the seem to acquire additional equipment which all too often ends up in the aft end. This coupled with a re power of engines with additional weight combines to make a real challenge for proper trim.
Steve
Old 10-26-2011, 06:58 AM
grady's Avatar
Novice
Rep: 70 Posts: 460
Hey Steve, Thanks for the reply. These Blackfins have a conventional bottom that's to say no prop tunnels. Pretty cool that you were involved with them back then.
Old 10-26-2011, 05:27 PM
Rep: 205 Posts: 442
Then put much larger tabs on them then are currently installed. Maybe go for 48 x 12 which are the smallest of the dual ram configuration tabs from Bennett. All you will need is the tabs with hinges, one additional ram per tab and a couple of Tee fittings and some tubing. You can re use the existing ram (if its a standard Bennett Ram) and just tee into the existing tubing. The system is self bleeding too so when finished installing just run the tabs up and down a few times.
The switch, wiring, pump all remain same and are quite capable of pushing dual ram 48 x 12 tabs.
Put a swim platform on and you won't even know they are there.
Steve
Old 10-26-2011, 05:45 PM
grady's Avatar
Novice
Rep: 70 Posts: 460
The boat I looking at has recessed tabs and with some rework on the bottom I'm sure its doable. And I have heard they do help. Some of the smaller boats have transom mounted tabs and do hide bigger ones under a swim platform.
Thanks for your continued interest and help.
Will it plane? F3M4 Multihulls 37 05-20-2011 12:10 PM
Is there validity to the notion that a pointy stern, a canoe stern, is safer at sea saltydog123 Sailboats 27 04-01-2009 03:20 AM
Round stern vs box stern?? Deadrise13 Boat Design 54 02-21-2009 03:23 PM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 07:36 PM
Naval Architect Fresh Graduate With Training Experience And Consultancy Experience anoop21 Services & Employment 0 07-10-2004 11:44 AM
