| unsupported span Hi all I have a simle question in longitudinal systems what is meant by unsupported span for the deck center girder CG ? is it the spacing between (transverse Web Frames) or the distance between the two BKHD (Bulkheads) that are carrying the CG ? i am using GL is it the same in BV? hope to find the answer here? thanks all Edit/Delete Message |
| Between bulkheads. The web frames are supported by, but do not support, the girder. They (the web frames) also have unsupported spans of their own. Those letter designations are not common building terms. Are you reading a plan? CG, for example, is empirically understood to mean Center of Gravity. Your're using terms that have different or no meaning outside of your particular circumstances/plans. Alan |
| you mean that the, unsupported span for deck girders is from bulkhead to another? right thanks for help ![]() |
I assume this only counts for the deck center girder and not for the other longitudinals (stringers) as those are supported by the transverse webframes. Or am I mistaken here? |
| Rule:unsupported span and spacing | Hisham | Boat Design | 1 | 11-18-2007 10:12 AM |
| little concern on Hydromax + looking for Span tutorials | Et' | Software | 2 | 03-07-2006 07:19 AM |
| life span of molds | Guest | Boatbuilding | 1 | 07-15-2004 01:55 PM |
| Outboard Motor Life Span? | Jeremy | Powerboats | 2 | 02-19-2004 06:05 PM |
| Life span of gel coat | Materials | 0 | 12-24-2002 02:52 PM | |
