| In general the length will be the main factor in transverse wave cancellation... but I would note that an asymmetrical hull with a very flat inboard surface would likely not produce as much of a wave between the hulls as a symmetrical hull would. Just a thought..... On CFD: I'm most familiar with Fluent (and not very, at that...); generally, CFD is great at comparison but poor at absolutes. That is, for two hulls, the ratio of any given parameter for one hull to the same parameter for the other will turn out very close to what it is in reality... but the actual values of those parameters will probably both be wrong by a bit. So it's great as a comparison tool, but is no substitute for a tank or a real hull in performance prediction.
Prof. Ernie Tuck at the University of Adelaide recently gave a paper on this topic. The paper is at: http://internal.maths.adelaide.edu.a...s/vortex04.pdf What he found (and I have verified numerically as well) is that asymmetric demihulls might be beneficial if the demihulls are not at their optimum spacing for a particular speed. If the demihulls are located near their optimum position, it is unlikely that you can reduce the drag by using asymmetric demihulls, or by using toe-in or toe out. Regards, Leo. |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 04:00 PM |
| Foiler Design | tspeer | Sailboats | 1031 | 12-17-2010 01:38 AM |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 05:44 AM |
| Multihull Project | Enora | Boat Design | 0 | 02-17-2004 01:21 PM |
| Multihull Project | Enora | Boat Design | 0 | 02-06-2004 02:47 AM |
