| Uniflite hull extension Hello everyone, I am new to this forum, and I wanted to get some opinions and ideas on a project I have. I own a '74 Uniflite 31' Sport Sedan, she has been partially submerged and is in need of a complete refit. While I absolutly love boats, I am not financially able to drop $50K for new Yanmars or Cummins, and a billion other parts for the cabin, etc, and THEN be able to afford to fill the tank on a weekly basis, probably getting around 1 MPG while I am out. So my idea is this; I have already decided on raising the front half of the cabin to a foward sloping pilothouse type design, the old Uni's did not have great visibility from the helm. (Note, my boat is one of the very few of this model that did not come with a flybridge on the roof) This part will be pretty easy. What I really need ideas on is the hull and the power. I am considering extending the hull 8-10 feet to make a large rear deck, more storage, fuel capacity for longer range cruising, and a more efficient hull. I would like to power this as a displacement hull, with maybe a single 5.9 Cummins. If possible, I would like to round out the hull extension to make the hull more efficient. The original 31' hull is a planing V hull, not sure of the deadrise out of memory. Beam is about 10'5". Is this a ridiculous idea? How would the boat handle? (assuming a good design on the ext.) What kind of material is the most economical (and strong) to use. Uniflites are a very heavy, thick, fiberglass construction. I am still very much in the idea phase, and looking to start making more of a plan for it. Another note, the boat as it sits has cost me $5000, so I am not risking a lot to start. Thanks a lot for any tips, ideas, etc.. |
| I am not a great fan of hull extensions. They tend to exxagerate any flaws that the boat already has. It has been done many times successfully by companies such as Hatteras, but they have a large design staff and experienced technicians to do the work. And typically when a a boat builder adds an extension it is not to an existing boat. They just build a new boat that is so many feet longer but is based on the shorter design. They don't normall just tack a few feet on an existing boat. This is because it adds new stresses, changes the centers of gravity and buoyancy, changes the pitch roll and yaw chacteristics, and the stress is concentrated at the poitn where the extension was added. I spent almost three years corresponding with a boat owner and the boat manufacturer over a boat that had been extended only 2 feet. The extension was literally falling off, and it was also causing big structural problems with the rest of the hull. Eventually the boat had to be scrapped and over 200 identical boats had to recalled by the manufacturer. The Coast Guard has a fleet 110 foot patrol boats 10 of which they had extended 13 feet. This was designed by professional naval architects, and done in a professional shipyard. Now the bows are falling off and they had had to tie those 10 boats to the dock until they can figure out what to do with them. (your tax dollars going to waste) So I suppose you can see why I am not a big fan of hull extensions. However, I am sure there are others on this forum who will disagree.
__________________ Ike "Don't tell me that I can't. Tell me how I can!" New Boatbuilders Home Page My Boat Building Blog My Boating Safety Blog |
| I can certainly see where you are coming from. I am not terribily worried about structural issues at this point, perhaps because I don't have a clue tho. I am figuring on leaving the existing transom in place as a sort of bulkhead, and by sistering up to the exisiting stringers (2x8 I think) I think I can keep the boat rock solid IF I use the right materials. Once again, I am only planning on running at displacement speeds as well. I have heard of Padden Creek Marine doing many extensions on the 42 and 48 foot Uniflites with no problems. They also cost a ton of $$ though. |
| AK, Just find another Uniflite 31 and bolt them togather at the transom. I believe they have a warped hull, so with a little fairing in the "middle" you could have a perfect canoe. A single engine should easily drive it at displacement speed, and you could have 3 spares. Dont let anybody tell you that it cant be done, and remember that brute force and ignorance will always prevail over intelligence and planning... Seriously, though, I think an extension of 5 feet of less and a tunnel for the single prop might make an economical cruiser out of that hull. The cost of the project is another matter. You could probably buy a lot of fuel for the cost of the mods. |
| What kind of materials would be best to do this with? I was thinking a plywood core with glass??? |
| you need to use way better stuff than wood arora matt core and penski board stringers or a composite of 10 lb density 24 lb for transums uniflights has a huge delamination history not worth all the effort in my opinon they tried some years ago to develope a fire retarded gel-coat that never worked very well you should look for another hull entirely |
| Not any delam problems with this boat. And it is prior to the years when they started having problems with the fire retardant in the resin. Although, I am starting to think about getting rid of it and start building a steel Diesel Duck 48. |
At the end of the day, your project would take a Uniflite 31 and turn it into a home-built. Not automatically bad, but be sure you really want to take on that responsibility.... and if you do, be rigorous in seeking out and using only the best materials and procedures. Good luck! Last edited by charmc : 01-30-2007 at 10:02 AM. Reason: grammar and needed to add a phrase |
| I love this Uniflite Are you still considering selling your Uniflite? The model you have is an awesome boat just as it is. You made a small mention of getting rid of it. If that's what it comes to, please let me know. These 31's aren't that easy to find. Thanks, Brian bspmarine@gmail.com |
| [quote=charmc;123692]Had a little experience replacing a rotted transom that was plywood core. Most definitely forget the plywood; there are marine rated composites for core material, as suggested above. If you use good materials and techniques, plywood can be an excellent core material. It is very strong and easy to work with, but it doesnt get along well with water. (Not to say that the same does not apply to all core materials) I have done succesful transom additions on boats in the 30' range. It is fairly easy if the chines are parralel, but if it is a displacement or semi disp. hull, you must do some serious number crunching before attempting to stretch the hull. 8-10 feet is a huge addition on a 30' hull. I would be comfortable with 3, hesitant at 5. Good luck with your project, Don |
| Stern extension | Tactic | Sailboats | 51 | 07-29-2007 01:36 AM |
| boat extension | ccblast | Boat Design | 5 | 10-22-2006 12:13 PM |
| Hull extension planning - HELP! | jgdyer | Boat Design | 0 | 07-18-2006 11:17 PM |
| Megregor Extension | watsonfleet | Boat Design | 0 | 05-23-2005 05:27 PM |
| Hull Length Extension | SuperPiper | Sailboats | 5 | 11-04-2003 09:29 AM |
